VideoHelp.com Forum
    Hello -
    Using the Apple Activity Monitor, it appears that 99% of one processor is tied up between FFmpegX (5%) and MemCoder (95%), leaving half of the processor resources in my Mac (dual G4 1.25GHx) machine underemployed (about 15% total use).
    Is there any preference of other means to enable FFmpegX to use these untapped resources?
    Would appreciate learning that method, if one exists.
    williamd
    Not all of the encoder choices may be multiprocessor aware. Mpeg2enc definitely is, so if your conversion can make use of it, try that, and select the appropriate "thread" option in the Options panel.
    Thanks for your response
    Had a possibly interesting thought - after Checking various encoder web-sites, and -- sure enough, work is underway with some encoders to achieve a state of "multiprocessor awareness" !!
    However, they are presenting their efforts as a 'Multi-Core' adaptation of the encoder - no clue how this applies to 'multi-prosessor' in the sense of a Dual G4 or G5 machine.
    Most of the work I do is conversion of VOB (1GB) files into DivX -
    Ever suppose simultaneous running two FFmpegX (renamed 'FFmpegX1' and 'FFmpegX2') copies is possible? Might FFmpegX1 take input from a folder holding the ODD VOBs, and FFmpegX2 from an EVEN VOBs folder....
    My immediate concern is that the preference and temporary files remain separated for each copy of FFmpegX...no doubt there is more to worry about than that...
    AN AFTERTHOUGHT - What (if possible), might this trick do for four-core and eight-core machines....imagine the speed possible!!
    williamd
    In principle, running multiple threads on multiple cores/processors should work properly. I say give it a try and see if the OS does the right thing. If written properly, one should be able to take advantage of as many cores as are available. For video encoding in particular, it is relatively easy to partition tasks in the right way. Whether or not that's actually done right is another thing.
  1. request/ question ffmpegx and multi processors
    By terramir in forum ffmpegX general discussion
    Last Post: 18th Dec 2011, 22:52
  2. How do I burn multiple subtitle tracks to a DVD with ffmpegx
    By wildgeese in forum ffmpegX general discussion
    Last Post: 26th Feb 2009, 11:54
  3. ffmpegx multiple files at once
    By Trent1982 in forum ffmpegX general discussion
    Last Post: 8th Aug 2007, 14:17
  4. ffmpegX and multiple tracks
    By jelockwood in forum ffmpegX general discussion
    Last Post: 30th Jul 2007, 10:55
  5. multiple files at once in ffmpegX
    By sweck in forum ffmpegX general discussion
    Last Post: 14th Jul 2007, 17:38
