Hi again folks,
My constant trauling through the world wide web has led me to find that my Sony Handycam has recorded movies in three different types of MPEG format. Some of the movies are not supported on my PC, hence the icon having a grey box around them. Aparently I need the relevent codec to be able to work with these. Can anyony be more specific here, as now my brain is throbbing!!
Can I download the relevent codecs? What the hell are codecs?? If anyone can help me I will be eternally grateful.
Regards,
Si
Thread: Vid Codec issues..
Codecs are the small pieces of software that decode (or encode) video.
If you just want to watch the videos, the simplest solution might be to install a player such as VLC or The KM Player, which have a lot of built-in codecs and can play most formats.
If you want to edit and re-encde then you first need to determine what codecs you need. Programs like MediaInfo and G-Spot can tell you this. Once you know what you need, you can download that codec, install it, and play your videos.
Do not be tempted to take a scatter gun approach to solving your problem by installing a codec pack. Despite what some might tell you, these are bad news.
THis is sony camcorder, is it HD camcorder? if yes it is avchd format camcorder for sure.
then the simplest solution for avchd is Splash player. playbacks AVCHD much better than kmplayer and vlc.
but... it doesnt support mpeg-2 yet
Kmplayer and vlc like guns1inger said have lots of codecs and will play mpeg-2 footage very well, but in my opinion both suck at avchd :/
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum CapturingReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Codec Conflicting Issues
By ohnoeee in forum Newbie / General discussionsReplies: 18Last Post: 7th Apr 2011, 11:47 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48 -
serious codec issues mac?
By aceswild in forum MacReplies: 10Last Post: 20th Nov 2009, 13:45
Statistics
Newest guides
Latest tool updates
New media comments
