Hi to company!
I have a problem with playing fulHD video (h264, ts) with my PC:
P4 3.0 Ghz
Gigabyte Ati Radeon 9600 Pro AGP8x (256MB)
1920x1080 HDMI Samsung LCD panel (TV)
2 GB RAM
120 GB & 450 GB SATA HDD's
Board: ... P4P800SE
WinXP Pro SP3.
720p plays good but CPU usage rises upto 50%. Trying to play 1080p format stucks picture every 3-4 seconds while CPU used 100%. Where is the bottleneck here? The card or wrong setting somewhere?. Thanks in advace for your response.
Results 1 to 11 of 11
Both video card and cpu are bottle necks,you will need at least a dual core and a good pci-e video card,my amd64 3400 wiith a 7800gs couldnt play a 1020 video smoothly till i got a amd x2 6000 with a 8600gts.
Ben Johnson-I didnt take any stereos!
Oh, I see. It looks like that. That is really bad news. Thanks nevertheless, johns0.
Your system should be fast enough to play 1080p/24 MPeg2 at >15Mb/s. It may be fast enough to play wmv-hd 1080p.Originally Posted by GeraDOT
It is not able to handle 1080p h.264 decode with that CPU and display card.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
O.K. That sounds much better!Originally Posted by edDV
Thanks edDV! So, what I have to do in such situation? Convert h264 to avi? Could you advice some good converters for it?
h.264 is a high compression codec that requires a fast CPU+GPU to decode in real time.
You can recode non realtime to MPeg2 at @ >15Mb/s* and have a good chance to play that file in real time. The MPeg2 file will be several times larger.
*this is equivalent to HD broadcast format.Recommends: Kiva.org - Loans that change lives.
What you think about such a card:
SVGA PCI Express,2 GB, Palit, Revolution 700 D, ATI Radeon HD4870X2, HDMI/DVI/DP, [AE5487XSF0545] ?
Coud it be used in my PC?
that video card is probably overkill unless you are doing gaming as well. Again, if you are doing gaming, your CPU is going to be a big bottleneck.
For HD you could get the radeon 4830 for well under 100 dollars, make sure your motherboard has pci-e slots...being a p4 it may not.
To play 1080p24 h.264 you need one of two things: either a dual core CPU (and multithreaded h.264 decoder like CoreAVC pro or a recent version of ffdshow) or a graphics card with hardware h.264 decoding (and a player that supports DXVA, the Microsoft subsystem used for hardware decoding). Of course, it doesn't hurt to have both.
yeah you also need a decent software player if you want to play hd-dvd or bluRay...and those I believe are buggy at best.
Thank you all for contribution to this thread!
I'm not a gamer, too old for that. ))) I just like to watch sometimes a movie of good quality pictures (since my eyesight is still good). I was sure that my PC is in more-or-less up-to-date state untill I got a set of HD-rips of 1080p movies encoded with h264. ))) In fact the PC is five years old))) and without the chance of further upgrade (no PCI-E, AGP bus). So it looks like the new computer is a must.
The best codec/settings & application to run a 1080p flawlessly?
By r2builder in forum MacReplies: 8Last Post: 19th Apr 2008, 17:47 -
1080p content -> 1080i HDMI -> FullHD Tv
By arturo83 in forum DVB / HDTVReplies: 4Last Post: 13th Apr 2008, 12:11 -
FullHD not really FullHD. Ripped off:(
By [.Q.] in forum DVB / HDTVReplies: 11Last Post: 9th Jan 2008, 12:38 -
Cant run 1080p out from my LG blue multi into my Aquos.
By huthmakerj in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jul 2007, 18:39
