VideoHelp.com Forum
Thread: flac to mp3
    sorry if this is already covered, just doing a quick post while at work
    i need to convert a lot of files from flac to mp3..... any free program that will do that?
    cheers
    can someone tell me how i can do a batch conversion? i cant work it out, i need to convert hundreds of files...everything ive loaded into foobar i want to convert
    now its saying something about lame?
    You need to pop the lame.exe file into your foobar directory (download it from here, use the 2nd link (LAME 39.8.2))!
  6. Member t0nee1's Avatar
    You need to install Lame and point foobar to lame.exe to use it..
    http://www.simplehelp.net/2008/11/06...t-audio-files/
    If you want to convert all the flac files you've loaded in f2k, just highlight them all (ctrl+A) and right-click--> Convert...
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
    Just get the Lame 3.98.2 exe file and drop in in your Foobar folder (in Program Files). Foobar will recognize it if it's in its installation folder.
    Then you just select all your songs in Foobar (shift-click) and then "right-click/Convert/..." and you can choose "mp3(LAME)" and go to More Settings and choose your quality.
    NOTE!! - If you want higher quality that Foobar's presets (eg you want 320 CBR) you need to make a few more mouse-clicks. LOOK HERE for simple instructions how to do this! Takes half-a-minute and you are set up for future 320CBR conversions.
    Foobar is a pretty ugly and kinda non-intuitive app but it is very cool nonetheless.
  1. flac to mp3
    By angryassdrummer in forum Audio
    Last Post: 7th Mar 2011, 01:48
  2. Converting Flac to MP3
    By Alexstarfire in forum Audio
    Last Post: 28th Jun 2010, 10:59
  3. Replies: 7
    Last Post: 12th Dec 2009, 10:12
  4. MP3 or FLAC to AC3
    By Benjy in forum Audio
    Last Post: 30th Oct 2009, 14:34
  5. Flac Files To MP3 Which Software??
    By Lennoxtown in forum Audio
    Last Post: 9th Sep 2007, 06:22
