VideoHelp.com Forum
Results 1 to 14 of 14
Thread: blu-ray writer
  1. If you were buying a blu-ray writer at this moment in time which one would you go for and why..
    Or if you own one would you rather have another or do you think its great..
  2. Greetings Supreme2k's Avatar
    I would (will soon) go for the cheapest with a good name behind it. I've seen a couple of the cheap ones in use for 2 years of pretty intense use and that is good enough for me ($120-$150 range now, about $300-400 then)
    Cheap LG is fine.
  4. I was thinking LG or PIONEER but as i have yet to order i might wait till over the weekend till i get some more feedback..
  5. Originally Posted by red lion
    I've been using the LG with no problems for about a year
  6. LG HD-Rom/Blu-Ray Writer combo. I have a lot of HD DVDs that I'm converting over to blu. You can have both hd dvd and blu ray access for the low price of $170. http://www.newegg.com/Product/Produc...82E16827136155
  7. DVD Ninja budz's Avatar
    Just FYI the PIONEER Blu-ray drives only work with VISTA according to the specs.
    http://www.newegg.com/Product/Produc...82E16827129016
    That pioneer is only a bluray reader not a writer.
  9. Mod Neophyte Super Moderator redwudz's Avatar
    I just ordered this Pioneer BD writer for ~$210US. Should get it in a few days. http://www.newegg.com/Product/Produc...82E16827129037 It will be installed in a Vista PC.
  10. DVD Ninja budz's Avatar
    It doesn't matter if it's a reader or writer, it's still only compatible with VISTA.
    Whoas @ redwudz! I'll know who to ask when it comes to BR dvd burning!
  11. Mod Neophyte Super Moderator redwudz's Avatar
    I got 'The fever' and a few spare dollars. The i7 will have to wait a bit longer.
  12. Originally Posted by budz
    So what about windows 7 as it looks like vista might be finished
    the LG drive is very tempting and proven but the new PIONEER writes at 8x
    http://www.play.com/PC/PCs/4-/956491...k/Product.html
  13. DVD Ninja budz's Avatar
    red lion if you want a BR writer that writes at 8x then that's the one you should get. Just my 2cents!
  14. Originally Posted by budz
    Its not really that but with dvd the write speed did not matter so much as you could still write a disc quite quick
    but with blu-ray the difference between write speeds are more important as its quite a slow process..
    although i have never seen 8x discs yet
  1. Which Blu-Ray writer are you using?
    By golfnut in forum Blu-ray Ripping
    Last Post: 2nd Apr 2012, 10:23
  2. Blu-ray writer driver
    By opticsman in forum Authoring (Blu-ray)
    Last Post: 30th Jun 2010, 07:52
  3. what's the best blu-ray writer available?
    By nick101181 in forum DVD & Blu-ray Writers
    Last Post: 20th Feb 2010, 05:45
  4. Blu-ray reader (rom) or Blu-ray Writer?
    By gll99 in forum DVD & Blu-ray Writers
    Last Post: 25th Aug 2009, 14:26
  5. Pioneer or LG Blu-Ray writer?
    By newworldman in forum DVD & Blu-ray Writers
    Last Post: 21st Aug 2009, 18:54
