hello
first sorry for my bad english , i speack frensh
I have a car dvd called ( HARDSTONE DPM-62) with dvd player / gps bluetooth ... and more , i am searching a hack for change the splash screen . but I can't access to a hidden setup for recognize the version of dvd or how i can update it , please if any one have an idea or response help me ...
thanx all .
Thread: hardstone DPM-62 Car DVD Hack
Car DVD players almost never have hacks, but maybe you will be lucky and someone will know one. It's not very likely though.
The typical hack is simply for removing the region check. In your case, you are wanting to modify the firmware. There isn't much information around for this type of project. I can only suggest countless hours on Google digging up the information and tools that you need.
Google is your Friend
thank you for your help friends, but my problem is just do not know the type of DVD software that I must update, the problem is that I want the equivalent of my car dvd.
i found a picture on the internet similar as my car dvd software
remembre , i need to change just a splash screen
thanx all
For what it's worth I knew what you meant. You can't use the simple "hack" to make the changes you want. The only "update", would be from the manufacturer. Any changes the manufacturer makes are typically to only correct operational problems, not cosmetic changes.
So your only option would be to try it yourself. You will need a copy of the firmware, tools for editing and then compiling it, and of course some source of knowledge on what exactly needs to be changed.
As hardly anyone modifies firmware on their own, I don't know where you will get the tools or knowledge needed. My only suggestion, as noted above, is to spend a lot of time on Google searching for information.Google is your Friend
Axis AX-0810 Car DVD
By Route74 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jun 2011, 00:43 -
Microvision In Car Dvd Player - need region hack please!
By vanishingbluepoint in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2008, 18:38 -
ASVM6271 Car DVD Player
By Pete W in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Dec 2007, 17:08 -
How to get audio track from DVD to CD, to play in car
By erinmck in forum MacReplies: 10Last Post: 18th Dec 2007, 22:51 -
DVD player in my car
By dan-mac in forum Newbie / General discussionsReplies: 3Last Post: 9th Jul 2007, 19:47
