I want to be able to transcode the attached MPG specs into and AVI huffyuv
without using Digital Rapids which is the only thing I can find
Any HELP will be greatly appreciated
Thanks so much !!!!
Results 1 to 20 of 20
Thread: HD MPEG convert to Huffyuv AVI
You can use DGIndex and MPEG2Source()
or you can open it up directly in virtualdub, with the mpeg2 plugin
get the huffyuv codec and encode it in virtualdubmpeg
And another option is avidemux, which includes everything
THANKS guys I will give these programs a try
Hey guys this is what I am using on my AVS script
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\VSFilter.dll")
DirectShowSource("V:\123.mpg")
mainaudio = DirectShowSource("V:\123mpg")
BicubicResize(1280,720,0.1,1.00)
It loads up on Virtual Dub with only (VIDEO) but no (AUDIO) ???
the mpg has (AES3 LPCM 302m)
you can see my MPEG specs above on my first post
any ideas guys ?
thanks
can you hear audio when previewing the script in mpc? (i.e. is your directshow system setup correctly to decode LPCM since you are using DirectShowSource() )
Also you setup 'mainaudio', but never use it ?
You can also use info() at the bottom of the script and it will tell you if audio is transmitted
You could use DGIndex , and NicLPCMSource() which is designed for LPCM audio;
vid=MPEG2Source(video.d2v)
aud=NicLPCMSource(audio.lpcm).DelayAudio(some value)
AudioDub(vid,aud)
No I cant hear audio playing from mpc
the only device I know that I can this kind of audio back is in Digital Rapids
so I know my mpeg does have audio
I am not sure how to set up directshow system correctly to playback AES3 LPCM 302M : /
and what do you mean by 'mainaudio' ?
I installed NicLPCMSource - this is the script I used
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MPEG2DEC.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\NicAudio.dll")
aud=NicLPCMSource ("V:\123.mpg", 48000, -24, 6)
AudioDub(vid,aud)
I couldnt use DGIndex because it doesn't see the .d2v file --- I have an mpeg
I get an error when using NicLPCMSource
see attached picture
note that my audio is embedded into my MPG
I really appreciate your help [/b]
You might not be using lpcm, it might just be pcm which is slightly different in the header. Can you post the mediainfo info from the mpg? (view=>text)
Directshow probably isn't setup to decode lpcm on your pc (can you hear audio from mpc when playing the .mpg directly , not the .avs)? If you don't have a proper directshow splitter and decoder, you can demultiplex the mpg and do what I suggested and it should work
You have to index it using DGIndex to generate the .d2v file, this will give you .m2v (elementary video) + lpcm (elementary audio). The delay value will be written in the audio name. In this example I used 150ms (so 0.150) Since you have 16bit audio in your 1st screenshot you should use 16 instead of 24
vid=MPEG2Source("video.d2v")
aud=NicLPCMSource("audio.lpcm", 48000, -16, 6).DelayAudio(0.15)
AudioDub(vid,aud)
You are right it is PCM according to the below specs of my MPG
V:\TEST.mpg
General #0
Complete name : V:\TEST.mpg
Format : MPEG-TS
File size : 66.2 GiB
Duration : 2h 58mn
Overall bit rate : 53.1 Mbps
Video #481
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Duration : 2h 58mn
Bit rate mode : Constant
Bit rate : 49.1 Mbps
Nominal bit rate : 50.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.988
Audio #482
Menu ID : 1 (0x1)
Format : PCM
Format profile : AES3
Bit rate : 1 920 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : -84ms
no the audio wont play directly on the windows player but video is fine
So there is no way to just input the mpg without de multiplexing into virtual dub ?
There might be another way, but not through your directshow setup as evidenced by WMP.
You might be able to use ffmpegsource("video.mpg",atrack=-1) on the .mpg for the audio to pass through
You can try Avidemux, it might be able to import the mpg directly with audio
Using DGIndex (and demultiplexing) is usually how it's usually done, and it should have been 2 channel, not 6 channel (I goofed up the script above), and I'm not sure if that's truly LPCM, so you might be able to use wavsource() instead of NicLPCMSource()
aud=NicLPCMSource("audio.lpcm", 48000, -16, 2).DelayAudio(0.086)
If you upload a tiny sample somewhere (e.g. mediafire, megaupload) I can examine it if you want
ffmpegsource didnt work
for audio
Avidemux did index at the beginning load up the video but couldn't decode the audio
wavsource didnt work
this sucks thanks alot though appreciate it
i wish virtualdub can take the audio so i can transcode it to huffyuv avi
thats why i wanna keep with virtualdub
oh by the way do you know the script to make audio 16-bit not 32-bit
because its weird when i load my avs onto virtualdub on two different machines
one read 16-bit for audio precision and the other computer reads 32-bit
Did you try that script from DGIndex and load the .avs into vdub to encode to huffyuv, that should work if it's lpcm audio which you screenshot suggests
Not sure what you mean . What type of audio, what avs script ?oh by the way do you know the script to make audio 16-bit not 32-bit
I am using
QTInput("S:\TEST\DuckTest2.mov", audio=true)
BicubicResize(1280,720,0.1,1.00).AssumeFPS(23.976)
this works fine on one computer and i can encode QT into huffyuv and audio and video play fine
but when i try it on another computer the virtual dub reads 32-bit i will attach a screenshot
remind you i am using the same source file
i even copied over the same pluggins from computer to computer
its strange i dont know why it wants to encode it at 32-bit on this computer and when the encode is done i cant hear any audio
but when i do the same thing on the other computer it does it at 16-bit and audio works fine when encode is done
i can upload a sample of that file via mediafire i guess - i never really used it so i will just do it without an account ? how can u find the file after im done
and let me try that dgindex again
Oh now I see you're talking about the QT ProRes file from the other thread? You should be more clear
I'm not sure why it wouldn't work with the same setup. Did it also have the same prores decoder and qtpro version (you need qt 7 or newer for audio pass thorough), same vdub version?
As for hosting sites, I don't think you need to sign up, it will give you a link once it's uploaded
sworry about that ... ya i am going to have and look into that making sure everything is the same
thanks
and here is the link http://www.mediafire.com/?sharekey=8...4e75f6e8ebb871
hope it helps
thanks alot man ive been going nuts trying to do this
you helped alot with the QT thread one too
also if you have whenever I responded to the QT thread because i was wondering if you can go to ProRes to Huffyuv avi
on a MAC its fine if you can do it on a PC but what about a MAC
thanks dude
i feel like you should be getting paid lots for all the wonderful help you are providing
DGIndex won't work , the audio type isn't recognized
You can construct a graph in graphstudio, 1 for the video, 1 for the audio. You need the Mainconcept MPEG Demultiplexer and Mainconcept Layer II Audio Decoder installed (which I assume you already have for encoding these videos). Other common splitters (e.g. Haali, Arcsoft) don't seem to recognize the audio, which is probably why all the other programs had problems.
The first is the video.grf, the 2nd is audio.grf. You have to split it because in graphstudio and DirectShowSource only 1 pin can be used at a time. Leave the pins at the end open (which normally connect to renderer). Now you can feed that .avs script into vdub to encode to huffyuv or whatever you want
vid=DirectShowSource("video.grf",audio=false)
aud=DirectShowSource("audio.grf",video=false)
AudioDub(vid,aud)
video.grf
audio.grf
And about the MAC, I don't have one so I don't know what works... :P
Cheers
haha oh I see about the MAC thing
but dude it took me forever to figure out to work with graph studio because I am not familiar with it
but it finally worked !!! dude im so stoked!!!!
how can i thank you
the computer i did it is the computer i do my captures from, that has digital rapids installed which came along with those
plugins like main concept video and audio decoder
is there a way to just install those two decoders on another computer
like one that has virtual dub that way i can transcode my videos on that computer and keep the capture one free
I did the test mpg to avi
comes out good
only thing is my audio is late , wasnt there a command for that ?
THANKS!!!
I'm not sure, the problem is most retail software won't even allow you to use their directshow filters outside of the program. It's odd that this is even works (mine came with mainconcept reference). The difference with QTSource() and avisynth is that it's open source and free, not retail software so it should work on any computer for free. This might violate your terms of agreement, but If you right click each box, you will get a properties panel, and a location for the .ax . If you copy that .ax to a 2nd computer then register that .ax it might work. There should be 3 of them, and you can try using graphstudio or radlight filter manager to register themis there a way to just install those two decoders on another computer
If it's a constant delay, figure out the ms delay in the avs script in a media player by pressing +/- to sync it up e.g. MPC. Write down that number and you can enter that delay in the script (in this example I used 0.5, or 500ms. If it's going the wrong way, switch the sign to -.I did the test mpg to avi
comes out good
vid=DirectShowSource("mainconcept video.grf",audio=false)
aud=DirectShowSource("mainconcept audio.grf",video=false)
AudioDub(vid,aud)
DelayAudio(0.5)
ya I tried copying files to other computer
first graph program didnt see the filters
so i downloaded the main concept reference
it now did see the filters but when i put video into graph program
the demultiplexer doesnt allow me to use it and it doesnt even have an out pin
THANKS FOR ALL THE HELP
and ya i have to mess around with the delay it looks like it will work just fine
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Apple Pro Res HQ .mov convert to Huffyuv .AVI
By christianolovesvideo in forum Video ConversionReplies: 8Last Post: 6th May 2009, 13:30 -
How can I convert WMV to AVI or MPEG?
By betlysmith in forum Video ConversionReplies: 6Last Post: 25th Nov 2007, 01:02 -
How do i convert VRO to Avi or MPEG ?
By CoffeehouseSchmuck in forum Newbie / General discussionsReplies: 7Last Post: 10th Sep 2007, 13:56
