i have two HDD in my system one is 160 GB and the other is 80 GB both are sata drives. I use pinnicle ultimate 12. should i use separate HDD for rendering will it speed up the operation. And further what should be the size of xp partition for the same purpose
Thread: video rendering
Partitioning doesn't do a lot for speed. It can help reduce fragmentation, but writing from one partition to another on the same disc is slower that writing from one physical drive to the other. My systems all have a smaller system drive (physical) - typically 80MB on older machines and 120 - 160 on newer machines - and multiple larger HDDs for data and projects.
How much of a difference it makes depends on what you are doing. If you are doing straight encodes or direct stream copies, you will gain some advantage. If you are doing heavy processing of the video then IO won't be the bottleneck, the CPU will, so you gain virtually nothing.
thanks . and is it true that smaller HDD are faster than larger HDDs
Read/write speed tracks rotational RPM more than capacity. Speed is reduced when the disk needs to seek. Thus defragmentation can speed the disk allowing a continuous write.
Rendering is usually CPU limited more than disk speed limited.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Video Rendering Server
By jamesfed in forum Video ConversionReplies: 1Last Post: 8th Jul 2010, 07:29 -
Does a better video card improve the quality of video when rendering?
By raysolomon in forum EditingReplies: 8Last Post: 3rd Mar 2009, 20:24 -
Video Rendering
By tapal in forum Authoring (DVD)Replies: 4Last Post: 23rd May 2008, 09:30 -
Video Rendering
By Dave1024 in forum Video StreamingReplies: 0Last Post: 9th Apr 2008, 23:27 -
Video rendering rate?
By capman21 in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 9th May 2007, 22:57
