VideoHelp.com Forum
Results 1 to 10 of 10
    converting MKV to XviD...
    -original ratio: 2.35
    -MKV ratio: 2.42
    -XviD ratio: 2.35 OR 2.40?
    Depends on whether or not there are black borders in the MKV to fill out the difference between 2.35 and 2.42 or if the video was just stretched to fill the frame.
    Also depends what the source was (the actual source, not the mkv). You rarely get exact 2.35 active image area on blu-ray, and usually you use mod16 so the mkv is a bit off as well
    I would just find something spherical, or some other known shape, and measure it. On the other hand, you probably won't notice a 3 percent AR error anyway.
    i'm not quite sure how it was done, my buddy helped me cuz i only know xvid stuff...i know we autocropped the video black bars to make the MKV, but we had to rush through the rest & somehow ended up with 2.42...?
    when i take a screenshot of the MKV, it shows without black bars, 1280x528
    i have xvid4psp, would it help if i checked the MKV with Media Info or MKV Info tools? i would have from the start, but it takes some time to transfer such a big file back to my HD ...
    XviD4PSP's Media Info tool
    General
    Count                            : 214
    Count of stream of this kind     : 1
    Kind of stream                   : General
    StreamKindID                     : 0
    Count of video streams           : 1
    Count of audio streams           : 1
    Video_Format_List                : AVC
    Video_Format_WithHint_List       : AVC
    Codecs Video                     : AVC
    Video_Language_List              : English
    Audio_Format_List                : AC-3
    Audio_Format_WithHint_List       : AC-3
    Audio codecs                     : AC3
    Audio_Language_List              : English
    Complete name                    : C:\Documents and Settings\All Users\Desktop\2009\720p\TEST720P.mkv
    Folder name                      : C:\Documents and Settings\All Users\Desktop\2009\720p
    File name                        : TEST720P
    File extension                   : mkv
    Format                           : Matroska
    Format                           : Matroska
    Format/Url                       : http://packs.matroska.org/
    Format/Extensions                : mkv mka mks
    Codec                            : Matroska
    Codec                            : Matroska
    Codec/Url                        : http://packs.matroska.org/
    Codec/Extensions                 : mkv mka mks
    File size                        : 6992632487
    File size                        : 6.51 GiB
    File size                        : 7 GiB
    File size                        : 6.5 GiB
    File size                        : 6.512 GiB
    Duration                         : 8610825.000
    Duration                         : 2h 23mn
    Duration                         : 2h 23mn 30s 825ms
    Duration                         : 2h 23mn
    Duration                         : 02:23:30.825
    Overal bit rate                  : 6496597
    Overal bit rate                  : 6497 Kbps
    Encoded date                     : UTC 2007-10-27 17:39:22
    File creation date               : UTC 2009-05-04 15:56:50.359
    File last modification date      : UTC 2007-10-27 22:42:55.546
    Writing application              : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
    Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Count                            : 119
    Kind of stream                   : Video
    StreamKindID                     : 0
    UniqueID                         : 1
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format/Url                       : http://developers.videolan.org/x264.html
    Format profile                   : High@L5.1
    Format settings                  : CABAC / 8 Ref Frames
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 8
    Codec ID                         : V_MPEG4/ISO/AVC
    Codec ID/Url                     : http://ffdshow.sourceforge.net/tikiw...?page=Getting+ffdshow
    Codec                            : V_MPEG4/ISO/AVC
    Codec                            : AVC
    Codec/Family                     : AVC
    Codec/Info                       : Advanced Video Codec
    Codec/Url                        : http://ffdshow.sourceforge.net/tikiw...etting+ffdshow
    Codec profile                    : High@L5.1
    Codec settings                   : CABAC / 8 Ref Frames
    Codec settings, CABAC            : Yes
    Codec_Settings_RefFrames         : 8
    Duration                         : 8602208
    Duration                         : 2h 23mn
    Duration                         : 2h 23mn 22s 208ms
    Duration                         : 2h 23mn
    Duration                         : 02:23:22.208
    Bit rate                         : 5590472
    Bit rate                         : 5590 Kbps
    Nominal bit rate                 : 5853000
    Nominal bit rate                 : 5853 Kbps
    Width                            : 1280
    Width                            : 1280 pixels
    Height                           : 528
    Height                           : 528 pixels
    Pixel Aspect Ratio               : 1.000
    Display aspect ratio             : 2.424
    Frame rate                       : 23.976
    Frame rate                       : 23.976 fps
    FrameCount                       : 206453
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Interlacement                    : PPF
    Interlacement                    : Progressive
    Bits/(Pixel*Frame)               : 0.361
    Writing library                  : x264 - core 56 svn-680
    Encoding settings                : cabac=1 / ref=5 / deblock=1:-3:-2 / analyse=0x1:0 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=4 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5853 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
    Language                         : eng
    Language                         : English
    Audio
    Count                            : 102
    Kind of stream                   : Audio
    StreamKindID                     : 0
    UniqueID                         : 788999819
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Codec ID                         : A_AC3
    Codec                            : AC3
    Codec                            : AC3
    Duration                         : 8610825
    Duration                         : 2h 23mn
    Duration                         : 2h 23mn
    Bit rate mode                    : CBR
    Bit rate                         : 640000
    Bit rate                         : 640 Kbps
    Channel(s)                       : 6
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Rear: L R, LFE
    Sampling rate                    : 48000
    Sampling rate                    : 48.0 KHz
    SamplingCount                    : 413319600
    Language                         : eng
    Language                         : English
    XviD4PSP's MKV Info tool
    + EBML head
    |+ Doc type: matroska
    |+ Doc type version: 1
    |+ Doc type read version: 1
    + Segment, size 6992632451
    |+ Seek head (subentries will be skipped)
    |+ EbmlVoid (size: 4025)
    |+ Segment information
    | + Timecode scale: 1000000
    | + Muxing application: libebml v0.7.7 + libmatroska v0.8.1
    | + Writing application: mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
    | + Duration: 8610.825s (02:23:30.825)
    | + Date: Sat Oct 27 17:39:22 2007 UTC
    | + Segment UID: 0x96 0x2e 0x3b 0xc8 0xf2 0x45 0x36 0x17 0x9f 0xf3 0xb6 0xc8 0xba 0x57 0x63 0xbb
    |+ Segment tracks
    | + A track
    |  + Track number: 1
    |  + Track UID: 1
    |  + Track type: video
    |  + Enabled: 1
    |  + Default flag: 1
    |  + Forced flag: 0
    |  + Lacing flag: 0
    |  + MinCache: 1
    |  + Timecode scale: 1
    |  + Max BlockAddition ID: 0
    |  + Codec ID: V_MPEG4/ISO/AVC
    |  + Codec decode all: 1
    |  + CodecPrivate, length 68
    |  + Default duration: 41.708ms (23.976 fps for a video track)
    |  + Language: eng
    |  + Video track
    |   + Pixel width: 1280
    |   + Pixel height: 528
    |   + Interlaced: 0
    |   + Display width: 80
    |   + Display height: 33
    | + A track
    |  + Track number: 2
    |  + Track UID: 788999819
    |  + Track type: audio
    |  + Enabled: 1
    |  + Default flag: 1
    |  + Forced flag: 0
    |  + Lacing flag: 1
    |  + MinCache: 0
    |  + Timecode scale: 1
    |  + Codec ID: A_AC3
    |  + Default duration: 32.000ms (31.250 fps for a video track)
    |  + Language: eng
    |  + Audio track
    |   + Sampling frequency: 48000
    |   + Channels: 6
    |+ EbmlVoid (size: 1024)
    |+ Cluster
    Without actually seeing the video, and a section with something of identifiable aspect ratio, or the original video for comparison, there's no way of saying how you should handle it. Even if there are no black borders encoded into the frame it's possible that a little of the picture was cropped in order to maintain the proper aspect ratio of the source within the 1280x528 frame.
    You are simply going to have to eyeball it. And if you can't tell which is right, then it doesn't matter, does it?!
    true hehe, i see...i guess i'll just redo the mkv properly when i get it back from my brother...until then, i'll just run an xvid at 2.4 since my input.MKV is 2.4...thanx for the info bud...
    btw, since the source is so sharp and nice already, is there any point in using any denoise/sharpening or brightness/contrast settings with my conversion to xvid?
  1. Changing aspect ratio on an mkv?
    By vato76 in forum Newbie / General discussions
    Last Post: 14th May 2011, 10:11
  2. MKV and AVISynth: aspect ratio problems!
    By billyboy12 in forum Video Conversion
    Last Post: 6th May 2011, 04:16
  3. MKV Aspect Ratio
    By Valentin in forum Mac
    Last Post: 16th Aug 2010, 04:25
  4. how to change mkv aspect ratio?
    By johnnysv in forum Video Conversion
    Last Post: 27th Apr 2010, 02:51
  5. Setting aspect ratio for 1.33 MKV file
    By carlmart in forum Video Conversion
    Last Post: 16th Sep 2009, 06:43
