VideoHelp.com Forum
    My name is Marjan and I purchased DVD player P181 because it’s slim. But now I have problem with the subtitles. They are very small and I almost read them. There isn’t an option to resize them. So I tried to install the new firmware from the official site but when I insert the disk nothing happens the firmware isn’t recognized. I search the web and found lot of people with same problem so I decided to ask some help from you. So please help me with the subtitles and the firmware
    Thank you
  2. Member Krispy Kritter's Avatar
    I've never seen a player with a resizable subtitle font. So it doesn't surprise me that you can't adjust them.
    As for your firmware issue, you likely didn't properly burn the disc. The manufacturer typically supplies instructions with the firmware (either on their site or in the zip file) which outlines step by step how to burn the file. Their are often specific options to be enabled/disabled and it must be burned in a specific format. At least in my experience, you can't simply download and burn it to disc using default options like you would any other data files.
    Google is your Friend
  1. Samsung P-191 DVD player Firmware problem
    By stfly in forum DVD & Blu-ray Players
    Last Post: 19th Jun 2010, 09:17
  2. Problem with Samsung DVD-P181 ! Pls help !
    By lucianserpescu in forum Subtitle
    Last Post: 21st Mar 2009, 12:19
  3. new hack for samsung DVD-P181 needed
    By indigogirl1200 in forum DVD & Blu-ray Players
    Last Post: 9th Nov 2008, 19:58
  4. Samsung 1080P7 firmware
    By jsz in forum DVD & Blu-ray Players
    Last Post: 16th Jan 2008, 11:53
  5. Samsung DVD-P370 firmware problem, update disc not recognized
    By fleske in forum DVD & Blu-ray Players
    Last Post: 14th Aug 2007, 10:38
