Since Subtitle Workshop and some other tools don't do Unicode, yet SubRip can output Unicode, this presents a problem. Sub ReSync apparently groks Unicode because opening and saving a SRT with Unicode characters with it won't make it work with Subtitle Workshop.
How I fixed it.
Changed the .srt extension to .txt
Opened with Microsoft Word. (2003, other versions that do Unicode should work.)
Left the encoding on Unicode! If you try to change it on file open Word w i l l i n s e r t a s p a c e b e t w e e n e v e r y c h a r a c t e r. (Including between spaces, but this forum converts multiple spaces to one.)
Save as PLAIN TEXT, click OK then Word will pop up an encoding selection box. Choose MS-DOS or Windows Default and check the Allow Character Substitution box.
Change the filename extension back to .srt and subtitle tools should be able to open it.
Results 1 to 1 of 1
How can I make a unicode srt?
By X_Splinter in forum SubtitleReplies: 2Last Post: 18th Dec 2010, 13:04 -
How to Convert a Unicode SRT file to bmp or idx
By rezabrando in forum SubtitleReplies: 8Last Post: 11th Jan 2010, 14:27 -
SubRip does not want to save the resulting .srt file.
By salmond in forum SubtitleReplies: 4Last Post: 28th Aug 2009, 20:43 -
How to add .srt subtitle (With Unicode Lang) to a video with TMPGEnc XPress
By 9kamal in forum SubtitleReplies: 1Last Post: 18th Oct 2008, 21:09 -
Foregin subtitles UniCode (SubRip & mkvmerge)
By ronnlund in forum SubtitleReplies: 0Last Post: 9th Sep 2008, 04:19
