Results 1 to 12 of 12
    Hi Friends,
    I need clear idea for following Specs:
    I want to make 1CD(700 MB) movie from a DVD
    Run Time: 2 Hrs 30 Mins Movie
    Please suggest & answer the doubts here for great quality
    which is Best Resolution can be taken for 1CD (700 MB)?
    640 or 608 or 592 or 576
    which is best container for 1CD (Rips) with low bitrates(540 or 600 KBps)?
    X264 or MKV
    I would probably use 640 if you use the x264 video codec. But if the movies contains a lot of action scenes you might have to use lower resolution. Try convert some short examples and see for YOURself if it looks okey.
    And x264 is a video codec and mkv is a container...maybe you mean mp4 or mkv?
  3. Always Watching guns1inger's Avatar
    Why restrict yourself to an arbitrary 1 CD size file.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    I mean in which container, will the movie looks good either X264 codec( .MP4) or Matroska( .MKV) for 1CD size.
    Thanks 4 giving quick reply
    I want to make 1CD DVD-Rips with good quality without any blockings or pixel problems on maximizing the movie on any resolution in PC
    Thank You
  6. Always Watching guns1inger's Avatar
    You can't do it. 1 CD is not enough space to get a good quality clean encode that will look good fullscreen. You can have good quality, or you can cram it all onto one CD. But unless your running time is around 30 minutes, you can't have both.
    512x384 H.264 with 2-pass VBR, and a sub-1Mbps average bitrate (1.5Mbps max) ........ maybe.
  8. Always Watching guns1inger's Avatar
    The problem is that to get a clean encode at low bitrates you have to drop the resolution. The lower the resolution, the worse it will look when blown up to fullscreen on a high res monitor. It is a catch 22.
    http://www.youtube.com/watch?v=3suA7f-1oyc
    You are trading off resolution in order to get fewer macroblock artifacts. There is no simple answer to the question of what resolution is optimal for a 700 MB CD. It will depend on the movie.
    Use a resolution of 32x24 pixels and save as uncompressed RGB. That will fit on a 700 MB CD and you'll get absolutely no macroblock or DCT ringing artifacts. The video won't look very good blown up to full screen though!
  10. Video Restorer lordsmurf's Avatar
    Yeah, but the benefit of H.264 is the included anti-block filtering.
    Not a great solution, but what I suggested would be the best given the circumstances.
  11. The best resolution is not to do them. limiting yourself to 700mb creates too many compromises. Go to even 900mb and get much better quality, branch out into the uplands of 1200mb+ and you can really feel the quality, the room to breathe. Let the Bits run Free, without fear of running into each other.
    The electronic components of the power part adopted a lot of Rubycons.
  12. Get Slack disturbed1's Avatar
    X264 or MKV
    I think you might be a little confused about the quote above. x264 is a codec, like divx, xvid, theora .... for video, and mp3, ogg-vorbis, dts .... for audio. MKV is the container, as it contains video and/or audio, like MP4, AVI, OGM ...
    An x264 encoded video wrapped inside an MKV container will have the same quality if it was wrapped inside the MP4 container. It's the codec and codec's settings that decide quality. The container only contains the streams.
    If the question truely is about which container - if you are using x264 to encode the video, mkv is a good choice if you playback devices support it. If the question was about which video codec to use at such low bitrates - x264 has been shown to produce decent quality at low bitrates.
    As others have echoed above, at these bitrate limitations, the quality won't be fabulous . But if size is the number one concern, you don't really have a choice
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  1. Do faster rips = chance of bad rips?
    By vice86 in forum DVD Ripping
    Last Post: 14th Nov 2003, 15:26
  2. The best DVD to DIVX-fit on 1CD software
    By arvin in forum DVD Ripping
    Last Post: 25th Mar 2003, 00:48
  3. Replies: 7
    Last Post: 7th Feb 2003, 01:29
  4. smartripper rips bad resolution
    By asdf in forum DVD Ripping
    Last Post: 13th Jan 2003, 19:43
  5. Whatever happened to the guy with the 20 dvd - 1cd claim?
    By panterajake in forum Video Conversion
    Last Post: 12th Jan 2002, 05:35
About   Advertise   Forum   RSS Feeds   Statistics   Tools
