VideoHelp.com Forum
Results 1 to 10 of 10
    Hello,
    I am new in this forum and have very little knowledge about video convert. I tried to convert my DVD to mkv format. but i am having error. I have selected audio encoder as Nero AAC and decoding option as use eac3to as demuxer and decoder. but when i tried to convert HDConvertToX gave me an error tone and it cant convert audio. Output file is without audio. here is the log:
    C:\Program Files\HDConverToX\temp>"C:\Program Files\HDConverToX\applications\dgi
    ndex.exe" -FO=0 -OM=0 -YR=2 -AIF=[e:\top_ten_vtdvd\video_ts\vts_03_1.vob] -OF=[C
    :\Program Files\HDConverToX\temp\movie] -exit -minimize
    C:\Program Files\HDConverToX\temp>"C:\Program Files\HDConverToX\applications\eac
    3to.exe" "E:\TOP_TEN_VTDVD\VIDEO_TS\VTS_03_1.vob" 3: stdout.wav  -normalize  -do
    wn2   | "C:\Program Files\HDConverToX\applications\neroaacenc.exe" -if - -br 640
    00 -ignorelength -of "C:\Program Files\HDConverToX\temp\hdencodertox-pid3.mp4"
    *  Nero AAC Encoder                                         *
    *  Copyright 2008 Nero AG                                   *
    *  All Rights Reserved Worldwide                            *
    *  Package build date: Sep 17 2008                          *
    *  Package version:    1.3.3.0                              *
    *  See -help for a complete list of available parameters.   *
    ERROR: could not parse WAV file
    C:\Program Files\HDConverToX\temp>"C:\Program Files\HDConverToX\applications\x26
    4.exe" --bitrate 1500 --threads auto --thread-input --no-psnr --progress --keyin
    t 250 --bframes 3 --trellis 0 --ref 3 --filter -1,-1 --subme 5 --direct auto --v
    bv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --weightb --b-adapt 1 --
    partitions p8x8,b8x8,i8x8 --8x8dct --aud --aq-mode 0 --aq-strength 0 --output "C
    :\Program Files\HDConverToX\temp\hdconverttox_vts_03_1.h264" "C:\Program Files\H
    DConverToX\temp\hdconverttox_vts_03_1.avs"
    avis [info]: 640x272 @ 29.97 fps (8231 frames)
    x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
    x264 [info]: profile High, level 3.2
    [1.7%] 144/8231 frames, 16.04 fps, 1561.64 kb/s, eta 0:08:24
    What should i do?
    Thank You.
    Note: In this task there was no output file....
  2. please post the make report, and be sure to update to latest version of HDC
    i need to know the audio type of source vob
    also.. maybe you need to apply a telecine
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
    BHH
    I am using Latest Version: HDConvertToX v.1.3.259.2163
    Audio Type: 80: English (AC3 6ch, 0xBD 0x80) [0]
    I have applied telecine from De-Interlace Filter
    Make Report:
    HDConvertToX v.1.3.259.2163 report
    Input File: e:\top_ten_vtdvd\video_ts\vts_03_1.vob
    Codec Video: mpeg
    Width: 720
    Heigh: 480
    Framerate: 29.970
    Framecount: 434205
    Duration(hh:mm:ss): 4:1:28
    Aspect Ratio: 1.3334
    Resized resolution: 640 / 272
    Crop Left: 6
    Crop Top: 66
    Crop Right: 6
    Crop Bottom: 62
    Start Hidden Options ->
    -> End Hidden Options
    Start Video Configuration ->
    Encoding Settings: X264 in MKV
    Encoding Preset: 5
    Final Size: 1500
    Priority: idle
    Denoise Level: Super Light
    Force DirectShowSource: Off
    Deinterlace: Telecine
    -> End Video Configuration
    Start Audio Configuration ->
    Audio Codec: Nero AAC Audio
    Audio Bitrate/Quality: 64
    Audio Channels: 2
    MP3 Mode: abr
    SpeedUP: Off
    SlowDonw: Off
    Normalize: On
    Use Eac3to as demuxer
    -> End Audio Configuration
    Start Audio Tracks Selected ->
    -> End Audio Tracks Selected
    Start Subtitles Tracks Selected ->
    -> End Subtitles Tracks Selected
    Mux Subtitle in MP4/MKV file: On
    Encrust Subtitle in Video file: Off
    Start Advanced AviSynth ->
    Basic Filter: RemoveGrain(mode=2)
    QMF Filter: NONE
    MVDegrain: NONE
    FreeAVS String:
    ColorMatrix: On
    GreyScale: Off
    -> End Advanced AviSynth
    Start Queue ->
    "C:\Program Files\HDConverToX\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[e:\top_ten_vtdvd\video_ts\vts_03_1.vob] -OF=[C:\Program Files\HDConverToX\temp\movie] -exit -minimize
    "C:\Program Files\HDConverToX\applications\eac3to.exe" "E:\TOP_TEN_VTDVD\VIDEO_TS\VTS_03_1.vob" 3: stdout.wav  -normalize  -down2 | "C:\Program Files\HDConverToX\applications\neroaacenc.exe" -if - -br 64000 -ignorelength -of "C:\Program Files\HDConverToX\temp\hdencodertox-pid3.mp4"
    "C:\Program Files\HDConverToX\applications\x264.exe" --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 3 --trellis 0 --ref 3 --filter -1,-1 --subme 5 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --weightb --b-adapt 1 --partitions p8x8,b8x8,i8x8 --8x8dct --aud --aq-mode 0 --aq-strength 0 --output "C:\Program Files\HDConverToX\temp\hdconverttox_vts_03_1.h264" "C:\Program Files\HDConverToX\temp\hdconverttox_vts_03_1.avs"
    "C:\Program Files\HDConverToX\applications\Chapter\ChapterXtractor.exe" "E:\TOP_TEN_VTDVD\VIDEO_TS\VTS_03_0.IFO" "C:\Program Files\HDConverToX\temp\chapters.txt" -p5
    "C:\Program Files\HDConverToX\applications\mkvmerge.exe" -o "E:\TOP_TEN_VTDVD\VIDEO_TS\a.mkv" --default-duration 0:23.976fps --aspect-ratio -1:1.7880 "C:\Program Files\HDConverToX\temp\hdconverttox_vts_03_1.h264" --chapters "C:\Program Files\HDConverToX\temp\chapters.txt"
    -> End Queue
    AviSynth Script ->
    Working with files: C:\Program Files\HDConverToX\temp\hdconverttox_vts_03_1.avs
    #HDConvertToX Avisynth Script
    #Input File = e:\top_ten_vtdvd\video_ts\vts_03_1.vob
    #Original Resolution = 720x480
    #Aspect Ratio = 1.3334
    #Frame rate =29.970
    #Number of Frames = 434205
    #Lenght (hour:minutes:seconds) = 4:1:28
    #Display Aspect Ratio = 1.7880
    #Aspect Error = -24.0114
    #Resized resolution = 640 / 272
    #Crop Left = 6
    #Crop Top = 66
    #Crop Right = 6
    #Crop Bottom = 62
    #Source File
    mpeg2source("C:\Program Files\HDConverToX\temp\movie.d2v")
    #Insert Deinterlacer
    tfm(last,d2v="C:\Program Files\HDConverToX\temp\movie.d2v").tdecimate()
    #Applying Resizing
    GaussResize(640,272,6,66,-6,-62,p=60)
    #Insert Filters As Requested
    ColorMatrix(d2v="C:\Program Files\HDConverToX\temp\movie.d2v")
    hqdn3d(1)
    RemoveGrain(mode=2)
    -> End AviSynth Script
  4. eac3to seems unable to process audio.. that's strange
    could you please post a fragment of vob ? (just for more testing)
    i suggest to try checking "Use NicAudio/SoundOut" plugin
    second try will be creating manually the d2v (using "DG Indexer" on Utility panel) and demuxing the audio track
    BHH
    BHH
    I have tried both "Use NicAudio/SoundOut" & "DG Indexer" but same error tone.
    I dont understand the fragment of VOB....
    What to do...???
    I tried the same file with AutoMKV & AutoMKV can convert the file to MKV successfully...
  6. try indexing manually the vob
    imho it has some problem
    BHH
    If i select "Force DirectShowSource as Decoder" then video successfully converts to mkv....
  8. dss can be more robust to analyze/decode then eac3to
    BHH
    I have one more question....
    I also use AutoMKV. But when i want to convert 'MKV files with aac audio' to 'mkv files with nero aac or copy audio' then my output file contains only video no audio in output file.
    What is the problem?
    Sorry for off topic...
    Please help....
    Thanks for really fast reply...
  10. aac audio extraction from mkv is somehow broken on automkv
    another reason why i start developing hdc
    BHH
  1. Color problem after encoding with HDConvertToX 3
    By Romeo26222 in forum Newbie / General discussions
    Last Post: 30th Nov 2010, 06:23
  2. Problem with HDConvertToX
    By joy in forum Blu-ray Ripping
    Last Post: 23rd Jul 2010, 07:51
  3. problem with hdconverttox and dts audio
    By catfishblues in forum Blu-ray Ripping
    Last Post: 6th May 2010, 10:54
  4. HDConvertToX & Haali Media Splitter Problem
    By GreenGrass in forum Blu-ray Ripping
    Last Post: 23rd Aug 2009, 10:00
  5. HDConvertToX
    By ratboys in forum DVD Ripping
    Last Post: 10th Apr 2009, 10:08
