I have followed directions to install SVCD2DVD and when it gets to the registration I click 'register' and nothing happens. When I try to run the program again it keeps going back to the registration.
How can I register this product so I can use it?
Thxs
Results 1 to 9 of 9
As you have vista - can you take a look at this thread about installation and Vista issues?
http://forum.videohelp.com/topic324278.html#1776530
(In particular: installation in a folder other than "Program Files" and running "As Administrator")SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I've gone back and uninstalled the program and reinstalled it and run it as an administrator and tried to get it registered again. It didn't work (I click on 'register' several times before the box goes away and nothing. I've 2ce restarted the computer and tried to launch SBDC2DVD again and it brings me back to the registration process.
Ok Drop me an email and we'll do the registration manually.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
this is the message i get when i try 2 encode or do anything w svcd 2dvd i used this on an xp pc 4 about 2 yrs and i get the same message as i get on my new pc so if any1 can help me fix this ty in advance @ the end of this message it says i have 2 have debugging enabled if some one can pm me or send an email on how to help would b awsome . i can encode the vid if i dont change any of the settings or sometimes it will do the samething when half the vid is encoded. also where do i get backgrounds 2 make a menu have been using the defult menu BG ty in advance
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at x3284ccece41ee22b.x067e7d569898d5a4.x19ca706a82a1a fdc(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.ComboBox.OnSelectedIndexChang ed(EventArgs e)
at System.Windows.Forms.ComboBox.set_SelectedIndex(In t32 value)
at System.Windows.Forms.ComboBox.WmReflectCommand(Mes sage& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1944.22334
Win32 Version: 2.0.1944.22334
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
DevComponents.DotNetBar
Assembly Version: 4.8.0.0
Win32 Version: 4.8.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Interop.DexterLib
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/Interop.DexterLib.DLL
Interop.NEROLib
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/BadgerSoft/SVCD2DVD%202%20BETA/Interop.NEROLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
That version is years out of date.... Can you try updating to the latest version?
is this a free upgrade if so can u send me a link please reply by email
It is for existing registered users. Drop me an email with your registration details (registered email address or serial number) and i will sort it out for you.Originally Posted by earnhardt
SVCD2DVD show up on finished product
By LongJohnSilver in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 14th Apr 2010, 13:58 -
registration problem SVCD2DVD
By stgreene in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Nov 2009, 00:32 -
SVCD2DVD registration
By brianbrian in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Sep 2007, 14:08 -
svcd2dvd / vista registration issue
By simonlee in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jun 2007, 14:54 -
Registration of svcd2dvd
By error in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 18th May 2007, 09:34
