VideoHelp.com Forum
  1. Member ranosb's Avatar
    Wanted to convert MKV to a format thats playable on a dvd player, avi or divx, which is better at retaining as much of the quality as possible?
    Would the best choice be using ConvertXtoDVD to a dvd9, if this is possible?
    Anyone?
    http://www.riverpast.com/en/support/...t/mkv/divx.php
    I wouldn't use RiverPast.
    ConvertXtoDVD, FAVC or AVS2DVD will all do a good job and conversion to DVD format. Xvid4PSP can be used to convert to Xvid encoded AVI suitable for playback on standalone machines.
    Which will preserve the most quality ?
    Depends on the quality of the source.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Or use Handbrake and convert to avi xvid.
  4. Member ranosb's Avatar
    Thanks! But I think that would be decompressing to re-compressing, but it would be playable.
    I think Convertxtodvd with either dvd5 or dvd9 setting(one that gives Excellent conversion) , keep aspect resolution would produce best quality results...
  5. Always Watching guns1inger's Avatar
    Anything you do will involve decompressing and recompressing. Your subject is MKV to AVI or Divx. If you use ConvertXtoDVD you get neither unless you re-encode a second time, which will definately reduce quality. If you want ot get a Divx AVI file then you want to do the convert directly from the MKV file, not from MKV to DVD to AVI.
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  2. Convert *.mkv to *.DivX
    By Frizze in forum Newbie / General discussions
    Last Post: 29th Dec 2011, 23:35
  3. Replies: 0
    Last Post: 3rd Jan 2011, 05:44
  4. Replies: 0
    Last Post: 16th Aug 2008, 08:47
  5. how to convert mkv to divx/avi without loosing its quality?
    By noskid21 in forum Newbie / General discussions
    Last Post: 2nd Sep 2007, 11:00
