ok guys I am looking for a good dvd recorder vcr combo right now I have the lg rc797t and a sharp dv-rw 360 in my bedroom but the region hack does not work or in the case of the sharp does not have one and I have to have a dvd player hooked up also that is hack to play region 1 dvds
can anyone recommend me a good new one that has a working region hack one that is ok with hd I have between £100 and £200 to spend on this any help would be good as I really need to get rid of the 2 separate dvd players just for region free
Results 1 to 11 of 11
Why a hack for region 1 uwhen sing a dissk
I thought Canada was region 1
Conbo's Are not looked upon very well by many and I don't think you will find one wiyj a HDD
Try A Wal-Mart store [good return policy]
If you don't like it bring it back
Same question: I need a DVD recorder/VCR combo. For an array of reasons (including characteristics, price, and local availability) I'm considering:Originally Posted by KateP- Panasonic DMR ES35
Samsung VR375
LG RC389
I would really appreciate an advice.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Thanks.
The '06 ES-35 is a decent machine. It has Panasonic's own silicon instead of the later buggy LSI (used on the EZ's as well as the '05 ES-20 and ES-40v) both terribly buggy machines which I would NOT recommend.
The ES-35 was the base combo of '06 while the ES-45/6 included HDMI upconverting. If the ES-35 is used you should really clean the spindle ASAP and try and not record much in speeds between 3+ hrs and 4hrs(LP)/disc. 4:01/disc and above will switch to 1/2 D1 and improve macroblocking for those longer speeds.
As LS's link mentioned '06 was probably the pinnacle year for DVDRs, my favorite combo would be the Panasonic ES-30v which is a '05 model year with dual displays which is very handy for dubbing from one side to the other. The '05 model year had slightly better build quality but the '06 model year wasn't bad either. Avoid the '07 and newer EZ series combos if you have little tolerance for bugs and quirks.
LSI encoder chipsets are better than Panasonic's own chips, for the best video quality. I don't know that the chips are at all buggy -- in fact, they are historically one of the most respected encoder chips ever used in DVD recorders. So much that many brands used to advertise "powered by LSI Logic" in promotional documentation online or in print -- even Panasonic.
Panasonic encoding is notorious for adding noise, blocks in Half D1 (main reason they pushed Full D1 where it never should have been done), and "cooking" the quality of gamma and/or luma. It did get better with time, though problems persist to this day.Answers to Common Video Questions:
The original poster is apparently lying about being in Canada. Note the reference to pounds (£) which are completely meaningless in Canada. The pound is the currency of the UK and this post makes better sense if one assumes that this person is actually in the UK and thus region 2. I have no problem with people not putting the correct country in their profiles (see mine), but in some cases they really should tell where they are at if it has relevance to what they are asking about and in this case it does.Originally Posted by LCSHG
DVD/VCR combos could rarely be made region free a few years ago when it was fairly easy to find region free DVD players. Now that almost everybody has caved in to Hollywood's demands and stopped making players that consumers can change regions on, I wish the original poster an awful lot of luck in finding any DVD/VCR combo that can still be hacked.
KateP appears to have long abandoned her interest in this subject, so we're all just posting for the benefit of others who might read this.
Yeah, but betocchi asked too -- few posts down. I answered for him.
LSI/Magnum chips may be a better encoder chip than Panasonics silicon but personally I believe every Panasonic with the LSI chip is quite buggy.Originally Posted by lordsmurf
Case in point the '05 ES-20 and ES-40 and then the '07 and newer EZ series recorders(all with LSI/Magnum silicon). It's been reported that all of these models are buggy and contain many timer related bugs. I've personally had a ES-20 as well as a EZ-17/27 and 28. They all had timer related problems as well as other quirks which required frequent resets(I've read similar problems with the ES-40v). Personally I'd trade any picture quality gain for increased reliability, after all if the DVDR doesn't record your event, or locks up during recording what good is it if the PQ is great.
Now I read post from someone at AVS (Dr1384 I think) who hinted it may be the software that drives the LSI chip that may be buggy. I'm not sure if that's true or not but again all I know is every US Panasonic DVDR that's contained LSI/Magnum silicon has been on the buggy side, for whatever reason.
Maybe someone who's familiar with silicon and software could shed some light on the parallel between LSI and the buggy Pannys. I'd really like to know the truth
One would have thought Panasonic could have fixed the bugs by now, after all they've been having the problems with the various LSI models since '05
Timer bugs and the lot -- not really related to the chipset.
DVD Recorder/VCR combo
By tj1182 in forum CapturingReplies: 4Last Post: 1st Dec 2009, 21:52 -
DVD Recorder/ VCR combo
By whitemtntn in forum DVD & Blu-ray RecordersReplies: 9Last Post: 7th Aug 2009, 22:30 -
HDD/DVD Recorder/VCR Combo
By pa555 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 22nd Jun 2007, 23:16 -
What's a decent DVD Recorder/VCR combo?
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Feb 2007, 01:56 -
Best DVD Recorder / VCR Combo under $300
By Louis Cyphre in forum DVD & Blu-ray RecordersReplies: 15Last Post: 10th Dec 2005, 18:46
