HI all,
i am encoding one of my DVD(a very old dvd) to x264 (mkv) file using Xvid4PSP.
but the DVD shows it has mono channel.
is there any wrong if i convert it two channels or 5.1 channels.
please suggest me.
thanks
There is nothing wrong with doing that. You can simply extract the audio, process it with Audacity to have 2 channels, then re-mux it to the mkv with mkvtoolnix. It will still be mono, but 2-channel instead of one (usually left).
Just be aware that any of these operations will increase file size. That may not be an issue, but just be aware of it.
As Supreme2k said, you'll end up with 2-channel mono; these conversions cannot recreate missing information, so mono stays mono. If you're trying to solve a problem with sound coming from only one channel, then this will do so. If you already have (mono) sound coming from two speakers, and hope to change that to true stereo (or even 5.1 surround), the answer is no, you won't be able to perform that miracle.
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 13:14 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
Best way to convert DVD-r w/ 1 channel audio to mono?
By progrocktv in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2009, 15:57 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
Statistics
Newest guides
Latest tool updates
New media comments
all for your suggestions
