I done some video in AE, short 30 second clip.
Rendered it to AVI without any compression, and then converted it via TMPGEnc to MPEG-1 format, constant bitrate on 7000 kbps.
And when I playback it on DVD player it skips, the format is fine, aspect ratio is fine, but the playback is jitterish, as if i it was made at 12 fps.
3 questions
1 - is the bitrate too high for smooth DVD playback?
2 - would it be any better if I converted it to VOB?
3 - should I convert it to MPEG-2 format which offers me interlace option (this one was rendered progressive)
Thread: Jitter playback on DVD player
For standalone DVD player playback, mpeg1 bitrate is far to high. The DVD specs say max 1280 kbps.
I would convert to mpeg2 which should also allow to use progressive source. Then 7000 kbps is fine.
All specs listed here: (upper left pane - WHAT IS - DVD)
http://www.videohelp.com/dvdGoogle is your Friend
I have made MPEG2 file (.mpg) and copied it to USB drive. When playing it in my standalone DVD player, the video jitters (looks like slow motion with very low fps). I have tried with 6000kbps, 3400kbps, 2000kbps. But the result is same. Even with 2000kbps video quality is blocky also.
What is wrong? I am using Pinnacle Studio 12 Ultimate.
Many players will not play "bare" MPG files properly -- it's not required by the spec. Author a movie DVD with IFO/VOB files.
Other possible problems if your DVD player can play bare MPG files:
The player may only have a USB 1.1 port, not USB 2.0. So it simple can't read data off the drive fast enough. Write it to a DVD instead.
The drive itself might be too slow. This isn't likely with a hard drive but some flash drives have very low read/write speeds.
Motion "jitter" on vhs to dvd but corrects if dvd player paused t
By victoriabears in forum Video ConversionReplies: 3Last Post: 16th Jul 2008, 18:16 -
CD-ROM playback problem - all formats jitter & skip
By hockey2112 in forum Software PlayingReplies: 4Last Post: 9th Jul 2004, 10:22 -
PS2 DVD playback jitter
By RiG in forum Authoring (DVD)Replies: 6Last Post: 17th Oct 2003, 03:30 -
NTSC DVDs & NTSC VCDs jitter in standalone DVD player
By Faisal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Jun 2003, 11:04 -
Choppy playback on stand alone dvd player. PC playback is ok
By landes in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2002, 20:23
