In converting my DVD's to x.264/h.264 I've turned to handbrake to encode and package them as MKV's. It's a brilliant tool and has really made the whole process simple. However I'm facing an issue now where I want to preserve the exact soundtrack as is on the DVD. I don't want to be re-encoding everything to AC3. Especially my DTS stuff. Of course RipBot does direct stream copy for audio, but it can't take DVD Video TS folders as inputs, nor optical drives the way that Handbrake can.
Are there any other one-click solutions out there? Or can someone point me to a guide that is detailed enough to walk me through a multi-step process of encoding video with x.264/h.264, keeping the audio untouched, and adding one channel of English subs to the package for a few foreign films?
Ripbot can import dvds but you have to select the first vob from the main movie vobset.
see http://www.digital-digest.com/articl...ide_page2.htmlFor DVD sources, the DVD folder (video_ts folder) will contain a lot of files, but you only need to load in the first file in the VOB set that contains the content you want to convert. For example, if you want to convert the main movie, then locate the set of VOB files that are largest in size.
Or try fairuse wizard or xvid4psp or megui with the builtin one click encoder.
Baldrick, such a heavy hitter, as usual you know how to give excellent answers and help, while tactfully reminding us that there are other places to look outside videohelp.com forums.
Thanks once again. I'll report back with my progress.
cut video and save as direct stream copy
By supercain in forum EditingReplies: 44Last Post: 29th Apr 2012, 06:55 -
No direct stream copy in vegas pro 11?
By supercain in forum EditingReplies: 13Last Post: 18th Dec 2011, 02:10 -
direct stream copy of a mkv file Q
By Information in forum EditingReplies: 5Last Post: 20th Jul 2009, 14:06 -
How do you direct stream copy in sony vegas pro 8.0?
By ZZen in forum EditingReplies: 3Last Post: 6th Jun 2009, 09:51 -
Direct Stream Copy for All Formats
By bigMach™ in forum EditingReplies: 10Last Post: 11th Jun 2008, 13:02
Statistics
Newest guides
Latest tool updates
New media comments
