I just bought a new i7 dell computer with vista 64. Supposed to be the most smoking fast computer. Problem is it will not boot up. Just hangs there with a blank black screen. Currently going through tech support and they have yet to find a problem with my system. Any ideas?
Results 1 to 10 of 10
Check all connections
Monitor ok? plug it into another pc to check
Is there power? do you hear the drive (if mechanical), and see lights turn on?
Try booting with 1 of 3 memory sticks at a time, then switch -
dell's problem not yours. it should have been tested before leaving the factory. send it back.
It worked initially. It will start to boot up so monitor is not bad. Gives me option to start windows normally or do repair. Each option gives black screen.
Gday,
Have you updated the drivers for the video card lately by manual update or windows update?. During POST it does not use the drivers specific for that video card, if it is allowable by Dell because it is under warranty (I assume) try another video card in it and see if it boots normally.
James. -
Originally Posted by troyvcd1
Originally Posted by troyvcd1 -
Well get this. Tried everything with dell tech support but system was dead. Agent said lets try one more thing. Took out 4gig of the 6gig of memory and computer booted up. Needed to reinstall vista 64 though and all my files will be lost. Asked tech support why removing the memory made the system boot. He said it was a "GLITCH" . I of course said "WHAT!!!!". He said everything is fine just reinstall windows and drivers and all is well. Well if it "Glitches" again I will definately be po'd.
Originally Posted by troyvcd1"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Disconnect the power cord from the power supply and then try to power the cpu up. I recall hearing a problem with Dell Studio cpus having a problem waking up from sleep mode. Do a search for"Dell Studio Wakeup" and you'll see what i mean.
Tech support did that wake up thing about a zillion times. It did not help. Tech support said as soon as you reinstall windows and the drivers then you can install the remaining ram and everything should be fine.
Samsung BD-D5300 Black Screen Of Death
By oldfart13 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Aug 2011, 12:35 -
Dell Inspiron 1520. Black Screen
By jollyjohn in forum ComputerReplies: 6Last Post: 16th Jun 2011, 23:03 -
Windows Vista laptop always starts up to blue screen of death.
By Super Warrior in forum ComputerReplies: 5Last Post: 26th Mar 2011, 18:56 -
Black Screen of Death in Sony Vegas Pro 9.0
By sonyvegaspunk in forum EditingReplies: 2Last Post: 29th Sep 2010, 21:37 -
The Vista Death Watch
By joepic in forum ComputerReplies: 145Last Post: 11th Jan 2008, 15:22
