Up until yesterday I had my computer hooked up to my 32" HDTV by Component cables. And it worked fine.
I installed a new programe, which then said I needed to update my graphics card drivers.
Which I did. So, new graphics drivers from Nvidia.
Now for some reason I have a black border all the way around my screen.
I've tried changing the Resoloution, running the TV optimisation wizard and also manualy altering the "HDTV Screen size" ... Yet none of it worked.
I've maxed the "Desktop Resize" function. But theres still a good inch of black border.
I never used to have this. Any ideas?
I've tried connecting by HDMI cable and it reverts back to a full screen desktop. (Although I dont want to connect via HDMI as theres no audio)
Any suggestions would be hugely aprecaited
Many thanks.
P.S. Hurry please![]()
Thread: HDTV Monitor Resize
tombowler,
I sounds like underscan. Perhaps your component port lost its settings when reconnecting. Make sure it (component port on TV) is set to 1 to 1 or Pixel mode. Additionally, make sure your desktop is set to the TVs native resolution. Probably on 32" HDTV (LCD? Make? Model?) it should be 1366x768. Some TVs may only accept 720p (1280x720) and upscale to its native resolution.
To account for you border, I'm guessing your TV has a native resolution of 1366x768, your component port is set to 1to1/Pixel mode and your desktop is set to 1280x720. I'd go for setting your desktop to 1366x768 as I mentioned above.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Need more data about your TV and/or monitor (native resolution? connection resolution?).
Is this a dual computer monitor - TV mode or clone?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Using my HDTV as a monitor for gaming
By Darco32 in forum DVB / HDTVReplies: 2Last Post: 31st Jul 2011, 04:37 -
HDTV box to monitor
By kanganova in forum DVB / HDTVReplies: 6Last Post: 7th Feb 2010, 00:32 -
How can I watch HDTV on my LCD monitor?
By TheSolidSnake in forum DVB / HDTVReplies: 4Last Post: 19th Dec 2009, 05:53 -
Using an HDTV as a laptop monitor?
By Wall-E in forum Newbie / General discussionsReplies: 19Last Post: 6th Oct 2009, 15:34 -
Monitor & HDTV Connections?
By Ray & Paula in forum ComputerReplies: 3Last Post: 23rd Jun 2008, 07:33
Statistics
Newest guides
Latest tool updates
New media comments
