VideoHelp.com Forum
Page 8 of 8
FirstFirst ... 6 7 8
Results 211 to 239 of 239
  1. Originally Posted by KurtF1 View Post
    i can't make it work using firefox 10 and latest flash version (11.x)
    i have a VERY strange problem... look at the image: on the left it's the flash folder on windows explorer, on the right it's the flash folder from edit pad lite... it's COMPLETELY different!!!
    btw, if i run the utility it says that the file is patched correctly, but the message is still there...
    I think right folder for Windows 7 64bit is C:\Windows\SysWOW64\Macromed\Flash
    but Windows simulate folder to C:\Windows\system32\Macromed\Flash for 32 bit programs, for more compatibility
    If you run the utility, but the message "Press Esc to ..." is still there, please follow this steps:
    1) Uninstall all version of adobe flash player from Control panel -> Programs and features
    2) Download and run Uninstaller for Flash Player 32bit and 64bit version from this page.
    3) Download and install adobe flash player from adobe and run Flash "Press Esc to ..." message remover
    yes, right folder is that one, but i followed your steps and still i have that message
    ps. right now in that folder under syswow64 i have no .ocx... just a Flash10x.ocx.temp that i think is left from previous installation...
    any further idea?
  4. Originally Posted by KurtF1 View Post
    any further idea?
    What happens now when you run patch program and click Mozilla Firefox ?
    what message or error message?
    any further idea?
    no error message, it just says that everything is fine (can't tell you the exact message cause if i do it right now it just says that patch is already applied)
  6. When you have opportunity, please install for test Chrome and run patch program click Google Chrome.
    write back with result
    Try run patch program as administrator, with right click on file and select Run as administrator
    Try replace manually by steps
    1) Install Flash 11,1,102,55 for Internet Explorer and Firefox (check that you have 11,1,102,55 version after install)
    2) Delete NPSWF32.dll, Flash11e.ocx files in location : C:\Windows\SysWOW64\Macromed\Flash (if you have problem delete files use Unlocker)
    3) Download attached FlashPatchedFiles.zip file extract and NPSWF32.dll, Flash11e.ocx files to location : C:\Windows\SysWOW64\Macromed\Flash
    info: Firefox using NPSWF32.dll, Internet Explorer using Flash11e.ocx
    if this not help, probably Flash folder in other location
    Try search for NPSWF32.dll file and replace it in other location
    i tried again the first instruction and this time it worked
    the problem was that i closed firefox to run flash uninstaller, but i had msn live messenger running and so most of the files were still there (even if the uninstaller didn't notified me... -_-)
    so this time i manually deleted every file both in system32 and syswow64 and it worked!
    thank you very much
    oh while i'm here, in the last few days i have this little problem on facebook (see attached image)
    could be a facebook problem or flash-related?
    Attached Thumbnails Click image for larger version
  9. I don't have Facebook, so I don't know what problem displayed on image
    Try different browser like google chrome
    google chrome have built-in flash plugin
    Instead of going through hoops to remove this message, head on over to this Adobe bug and cast your vote for this feature request. If everyone on this thread voted, we'd get this functionality into the player by default.
    https://bugbase.adobe.com/index.cfm?...bug&id=3058752
    11.1.102.62, all OK!
  12. Originally Posted by theshadowrunner View Post
    As long code line don't changed, searched by patch program
    on ALL versions will be OK.
  13. question: does this latest ocx file bypass the SPS / interlaced flag check ?
    Really would like to know how to do that and whether hardware acceleration for bbc iplayer is possible !!
  14. Originally Posted by arthurdent5 View Post
    Don't know
    but you can check for yourself.
    You can reverse changes made by automatic patch flash plugin program by simple install adobe flash plugin again
    Please check all Frequently Asked Questions on first post for more info
    Thanks a lot. This just made my day.
    It is nice that some people are able to fix the annoyances others build into their software.
    When Adobe comes out with another updated version, do I need run automatic patch flash plugin program again?
    Yes, after update.
    I assume that we need to download a new version of the patch program too.
  17. Originally Posted by Frank Bertelsen View Post
    Yes, after update.
    No. The patch program version 1.1, supposed to work on all version of flash
  18. Member
    On future versions too? How do you know what Adobe is going to do in the future?
  19. Originally Posted by Frank Bertelsen View Post
    Patch program work by this steps:
    1) Search string/binary code responsible for the "press esc.." message in Flash plugin file
    2) Found target
    3) Change only founded string code responsible for message
    Since a couple releases, Adobe installs a service to check for Flash Player updates
    But even if you disable "auto check for updates" in the Flash settings, the service still checks EVERY HOUR.
    To remove this new crap completely, run this from command prompt:
    sc delete AdobeFlashPlayerUpdateSvc
    This removes the new annoying service completely.
    Hope it helps,
    TSR
    Edit: the above is valid for Flash 11.2.202.228 and 11.2.202.233 released today.
  21. OOPS! It stopped working!
    I have been using this excellent solution for some time now with my Chrome browser, and it really worked with every new Flash update.
    Until now.
    When I try running it for the new version (11.2 r202) I get "File already patched" message, yet I see that enlightening "Press esc..." all over my full screen videos.
    PLEASE F1 ME!
  22. Member
    Until now.
    PLEASE F1 ME!
    Exactly my point. How can anyone make a piece of software, that will patch future versions of Flash? Adobe have probably changed the coding around the message, so that a search for a specific pattern no longer works.
    These things need constant attention and tweaking with every new version released, because people are going to be pissed off if something they rely on suddenly doesn't work anymore. Probably more than they were pissed of by the annoying message in the first place.
  23. Member
    To ^F1, make sure of the path [THAT THE PATCHED FILE IS LOCATED WHERE IT'S SUPPOSED TO BE FOR YOUR BROWSER]. The patcher still works perfectly fine with the latest Flash release 202.233, at least activex.
    To Frank, what the hell. Chrono made the patcher AS A COURTESY, in case you can grasp that concept. Take it or leave it.
  24. Member
    No. When people make things like this, they are obligated to maintain it in the future, because others start to depend on it. It is called responsibility.
  25. Member
    If you aren't sarcastic, I think the crack you're currently smoking is bad.
  26. Hi !
    This is strange, since I didn't change anything from other versions.
    Anyway I looked in the first post where it says the path of the patch for Chrome is:
    C:\Users\{USERNAME}\AppData\Local\Google\Chrome\Ap plication\{LATESTVERSION}\gcswf32.dll
    In my computer it was actually under:
    C:\Documents and Settings\{UserName}\Local Settings\Application Data\Google\Chrome\Application\{VERSION}
    I've tried to patch this file using the button "Other" in the patcher, but it still told me the file was already patched.
    So I searched for gcswf32.dll in my computer, and I got another instance, same name same size, in location:
    C:\Documents and Settings\{UserName}\Local Settings\Application Data\Google\Chrome\User Data\NPAPIFlash
    Now, when I patched that file, I was successful, and was able to see my full-screen videos crystal clear again!
    So all in all, keep up the good work, all the best!
  27. Originally Posted by ^F1 View Post
    Until now.
    PLEASE F1 ME!
    On latest Chrome ver. 18.0.1025.162 and latest built chrome Flash ver. 11,2,202,229 don't have problem
    the "Press esc..." message don't displayed
    Try uninstall and install Chrome and run again flash message remove patch
  28. For 10.0.12.36 what should be offset? and that that change?
  29. Originally Posted by Trust View Post
    Can you tell more specific?
    Cannot understand what you trying to ask.
  1. Replies: 1
    Last Post: 25th Dec 2011, 05:33
  2. Remove green/purple "bloom" from video
    By mikeveli20 in forum Restoration
    Last Post: 3rd Oct 2011, 15:08
  3. Is there a way to remove or cover the "bug" in a video?
    By HuffmanFamilyof4 in forum Newbie / General discussions
    Last Post: 24th Apr 2011, 21:57
  4. Gray "!" iTunes 8 annoying song location issue...
    By Nintendo Fan in forum Computer
    Last Post: 14th Jun 2009, 10:38
  5. Philips DVP 3140: Annoying black bar after pressing "play"
    By tt-jones in forum DVD & Blu-ray Players
    Last Post: 19th Sep 2007, 22:29
