Page 14 of 18
FirstFirst ... 4 12 13 14 15 16 ... LastLast
Results 391 to 420 of 518
    Apr 2014
    The Chrome button was the first thing I tried. It said patch successful or whatever. Still had popup. Came back to thread and followed all the different instructions I could find, including yours that I quoted. Nothing seems to work.
    Apr 2014
    I didn't even notice the Firefox part of the instructions I quoted. Oops.
  3. Apparently Chrome switch to HTML5 player in YouTube
    And right now you cannot change it to Adobe Flash Player in YouTube
    maybe in future you can change
    so message you see its from HTML5 player
    Apr 2014
    Okay, thank you.
  5. Originally Posted by 911jason View Post
    Okay, thank you.
    You have temporary solution by disabling Html5 player
    by renaming file ffmpegsumo.dll in Chrome folder
    rename for example to ffmpegsumo_.dll
  6. Any ideas or hints how to disable this idiotic message in HTML5?
  7. Originally Posted by Standard User View Post
  8. renaming file ffmpegsumo.dll in Chrome folder
    Many thanks for a reply! Unfortunatelly, using Firefox (
  9. Originally Posted by Standard User View Post
    You have message in Youtube?
  10. No, I switched to Flash player in Youtube and used the patcher from this thread(deeply grateful to the author. It even works on linux). However, there are many sites using HTML5 and there is no way to switch to Flash. As you know, in HTML5 the "Press esc to ...." message looks even more ugly than in Flash
  11. No, its not possible to remove message "Press esc to" in HTML5 player
  12. No, its not possible to remove message "Press esc to" in HTML5 player
    I still have a tiny bit of hope some reverse engineering gurus will remove this stupidness )
  13. What Firefox version?
    In 28 I haven't that message. Do they introduced from 29?
  14. Originally Posted by vididex View Post
    What happens when you go to full screen on this video?
  15. The first cat ever that takes a shower xDDD
    Nothing else. No message at all.
    Unless it is because I'm under "special conditions", this is running on Windows 2000 with Kernel extensions, I don't see any difference.
    Before post this, I tested with an XP virtual machine in different conditions, just in case, and the message appeared in a new profile.
    I remember now what you meant.
    Initially, irritated as all of you, I dig in about:config without success until I found this:
    http://superuser.com/questions/613794/disable-firefox-fullscreen-warning-with-html5-stuff
    Set the browser preference full-screen-api.approval-required to false.
    I typed too fast fullscreen and I didn't see that pref, the firsts times.
    What confused me was the fullscreen message when it was a permission.
    By the way, I warning that, just in case, setting this preference to false could be a problem as HTML5 canvas gets more and more popular. In the future, sometimes might be preferable to deny some sites fullscreen access.
    The individual permissions probably are stored in places.sqlite file but I didn't dig on that as I preferred to set that pref and forget anything else.
    Regards.
  16. Set the browser preference full-screen-api.approval-required to false
    Ha, it was really simple ) Many thanks!
    Sep 2014
    from pc
    hello
    i have chrome Versión 37.0.2062.103 unknown-m (64-bit)
    i have patched with utility name Flash Fullscreen Patcher v3.0.exe
    in my computer show this message in spanish:
Name:	Sin tÃ*tulo.jpg
    www.youtube.com is now full screen. Exit full screen mode (ESC)
    is possible remove this message ??
    thanks
  18. Originally Posted by elmorcilla View Post
    hello
    thanks
    Its not flash player
    its message in HTML5 player
    Right now not possible to remove in Chrome.
    HTML5 player message can be removed in Firefox
  19. Thank you SO much roma_turok and CHRONOMASTER!!! This has been annoying me for so long! This is now my favorite web page on the entire internet. Forever.
  20. Please update link to CHRONOMASTER's Adobe Flash Player Patcher.
    Today this file is no longer available
  21. Originally Posted by txtxt View Post
    Thanks for reporting
    changed link
  22. I've tried downloading Flash Fullscreen Patcher v3.0.zip a couple times, but the zip won't open.
  23. Originally Posted by Slickone View Post
    Try disable antivirus, then download again
  24. Originally Posted by roma_turok View Post
    I have. Same problem.
  25. Size 68.6 KB (70,258 bytes)
    Size on disk 72.0 KB (73,728 bytes)
  26. The final size after download should be 413.95 KB
    file name Flash Fullscreen Patcher v3.00 + Source.zip
    Try download with different browser like Internet Explorer, Firefox or Opera browser
  27. I'm using Firefox. The problem was I was right clicking the file and doing Save As. You have to left click it and go to dropbox first. That works. Thanks.
  28. Originally Posted by Slickone View Post
    Wow, you never try left click
    anyway I added "?dl=1" to the links that make them as direct link and skip dropbox page
