I am encoding a film I'm working on as an H.264 in an mp4 container from Premiere CS4. I need it to playback on a Popcorn Hour A110 and pass a 5.1 audio stream through an optical link to be decoded in a surround receiver. The problem with Premiere is that if you encode H.264/mp4 you can only select an AAC file as your audio format. Is there a simple program I can use to join an H.264 with a 5.1 DTS, AC3, or LPCM audio file? Thanks.
Thanks, mkvmerge works great. Now I have another problem, however. My media player has yet to implement support for greater than 2 channel audio in a .wav format. Is there a tool which allows conversion of 5.1 channel .wav to .ac3 or DTS? I've tried BeSweet and it doesnt report errors, but it doesn't generate a file.
eac3to, behappy, foobar2000 (if you download the plugins), avisynth + soundout, many more
for dts, you need surcode (not free) separately, and 6 mono wavs; or you can do this with eac3to+surcode as well using a single wav
lpcm to dts/ac3
By bigman1992 in forum AudioReplies: 9Last Post: 8th Dec 2010, 01:48 -
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 10:03 -
Converting LPCM , DTS and AC3
By Benjy in forum AudioReplies: 10Last Post: 8th May 2010, 05:20 -
Convert DTS stream to LPCM ??
By Browncoat in forum AudioReplies: 9Last Post: 1st Oct 2009, 16:48 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 17:42
Statistics
Newest guides
Latest tool updates
New media comments
