HI EVERYONE AND THANKS FOR THE HELP IN ADVANCE...HERE IS MY PROBLEM..I HAVE AN m2ts file of the movie 300 saved on my pc. I I HAVE RIPBOT264 installed with the required software it asks for ( ffdshow, haalia media splitter, and avisynth ) when i load the video and it starts demuxing the selected stream it stops at 26% and gives out this error
DIRECTSHOW SOURCE: COULDN'T OPEN FILE C:/TEMP/RIPBOT264temp/job1/video.mkv:
The system cannot find the file specified
(C:/temp/Ripbot264temp/job1/getinfo.avs,line 2 )
What do i do? i been searching for an answer for a few days and i always get the same result.
Thread: 300 giving me problems
have you tried all solutions I have added in http://forum.videohelp.com/topic358185.html#problems ? tsmuxer might help.
This is what i get from tsmuxer
output
SmartLabs tsMuxeR. Version 1.8.8(b) http://www.smlabs.net
VC-1 muxing fps not set. Get fps from stream.
Decoding VC-1 stream (track 1): Profile: Advanced@3 Resolution: 1920:1080p Frame rate: 23.976
Decoding AC3 stream (track 2): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6
Decoding TRUE-HD stream (track 3): Bitrate: 640Kbps AC3 core + HD data. Sample Rate: 48KHz Channels: 6
Decoding AC3 stream (track 4): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6
Decoding AC3 stream (track 5): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6
Decoding AC3 stream (track 6): Bitrate: 192Kbps Sample Rate: 48KHz Channels: 2
errors
Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\Documents and Settings\HOME\Desktop\300\300 blu ray\VOLUME_SET_ID\BDMV\STREAM\00026.m2ts
Im trying the How to convert a BluRay disc into a .MKV 720P file
guide now. never came across this one. ill post my results
BDRIP gives me this error when i try tro open the folder...index was outside the bounds of the array. what to do?
i meant BDInfo gives me the error
i been trying everything possible and no luck...no i get this from tsMuxer 1.9.9 under errors Only ADVANCED profile are supported now. For feature request contat to: r_vasilenko@smlabs.net. what do i do?
VHS transfer - ADVC-300 with TBC-1000 and BVP-4 - Potential Problems?
By OldMedia in forum RestorationReplies: 9Last Post: 10th Aug 2010, 01:33 -
Using AVDC 300 to monitor pal out of FCP. Problems?
By rovdog in forum CapturingReplies: 0Last Post: 12th Aug 2009, 19:02 -
Nvidia latest drivers giving me problems?
By Immortal25 in forum ComputerReplies: 7Last Post: 26th Nov 2007, 19:37 -
Giving Vista another try...
By Faustus in forum ComputerReplies: 17Last Post: 28th Jun 2007, 02:23
