VideoHelp.com Forum
    Hello,
    I'm new to this program.
    I'm using ffmpegx on Mac.
    I'm trying to convert .wmv to .mov so it can be easily editable in iMovie. However when I convert it to .mov the audio is completely out of sync from the start. The video looks choppy but audio sounds clear so it seems like it's the video quality/frame-rates that are giving me issues.
    What do I output it to?
    It is 320 x 240, 22.92 FPS, data rate: 1871.53 kps, length: 15:25 (MM:SS)
    I searched but can't find a relevant thread (and feedback on semi-relevant threads didn't work for me)
    ".MOV" is not specific enough. What kind of mov? MPEG4? Divx? What output parameters did you select? And what playback software did you use to evaluate the result?
    And post the contents of the progress logfile (click on the blue "i" in the Progress pane ).
  3. Explorer Case's Avatar
    I suppose the ".mov" is MPEG-4 (part 2)/AAC, as per ffmpegX preset.
    For easy editing in iMovie your should convert to DV, as that is iMovie's native file format.
    iMovie will use a higher resolution than 320x240, so your output will be scaled up to SD (720x480), having an effect on visual quality.
    iMovie will use a higher framerate (29.97 fps), so the conversion will add frames, which wil make it a bit choppy.
    For syncing, first try activating Decode with QuickTime (a checkbox in the Options tab). This option requires that QuickTime is able to read your source file, so install Flip4Mac, if you haven't already done so.
  1. HD PVR - Audio not synced with video
    By lacywest in forum Video Conversion
    Last Post: 29th May 2010, 09:20
  2. Video/audio not synced problem. (Avisynth)
    By michcio in forum Audio
    Last Post: 18th Jan 2010, 12:43
  3. Replies: 5
    Last Post: 13th Jul 2009, 22:59
  4. audio and video wrong synced.
    By michcio in forum Authoring (DVD)
    Last Post: 18th Feb 2009, 18:08
  5. Converting .rmvb to .mp4 (Audio not synced w/ video)
    By mikeeeeyy in forum Video Conversion
    Last Post: 14th Jan 2009, 23:44
