HI all, i'm trying to parse an avi file following avi file reference i've found in the net but i'm finding some structures in my file which doesn't match the expected format.
Can an avi file have several 'movi' lists?
My file seems to have an old avi index since it has a fourcc 'idx1', but every index entry is 32 bytes long. Is that correct?, Where can i find this 32 bytes long entries structure pattern to parse them?
The video an audio info is organised in rec lists, and the chunk id for chunks inside the rec lists is xxiv, which doesn't match any of the ids i've read about (db, dc, etc). Can you tell me what type of chunk it is?
Thank you so much for your help
Results 1 to 1 of 1
Thread: parsing an avi file
Tool link parsing screwups
By AlanHK in forum FeedbackReplies: 7Last Post: 30th Aug 2010, 03:21 -
Parsing SVC SSEI
By link3D in forum Newbie / General discussionsReplies: 0Last Post: 11th Aug 2010, 23:49 -
SOLVED!! - AutoMKV stuck on "parsing profiles"... (not respondin
By TooLFooL in forum DVD RippingReplies: 7Last Post: 3rd May 2008, 08:35 -
DVD authoring fails - 'error in parsing XML'.
By Levina in forum ffmpegX general discussionReplies: 12Last Post: 22nd Mar 2008, 09:10 -
Parsing error
By screenhoofd in forum ffmpegX general discussionReplies: 6Last Post: 6th Oct 2007, 07:17
