When I convert files in ffmpegX the resulting file either only has a couple seconds of audio, or none at all...
Any thoughts?
Thread: No audio in converted file
1/ What kind is your source file (format, video codec, audio codec)?
2/ What format is your target (which preset)?
3/ What does your Process Information log say? (Press the blue "i" in the Progress window to access the log.)
There should probably be a sticky for questions of the "I tried (X) and it didn't work; what could be wrong" variety. It sure would speed up getting answers to the OP, and reduce the number of times someone here has to ask them to provide some actual information.
1. Source video(.AVI, mpeg4, yuv420p, 1280x720)
Source Audio(adpcm_ms, 22050 Hz, mono, 88 kb/s)
2. I've tried different target presets, XviD, DivX, DV, MOV, MP4
3. Encoding started on Sun Apr 26 23:03:38 MDT 2009
FIXME:Hardenabling SSE and SSE2 without detection
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
CPU: Intel Pentium III Katmai/Pentium III Xeon Tanner (Family: 6, Stepping: 6)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0x9990c0
AVI file format detected.
VIDEO: [H264] 1280x720 24bpp 24.000 fps 3329.9 kbps (406.5 kbyte/s)
[V] filefmt:3 fourcc:0x34363248 size:1280x720 fps:24.00 ftime:=0.0417
Opening audio decoder: [msadpcm] MS ADPCM audio decoder
AUDIO: 22050 Hz, 1 ch, s16le, 88.7 kbit/25.15% (ratio: 11089->44100)
Selected audio codec: [msadpcm] afm: msadpcm (MS ADPCM)
MP3 audio selected
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=1280 h=720]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Forcing output fourcc to 58564944 [DIVX]
VDec: vo config request - 1280 x 720 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: libavcodec (1280x720 fourcc=58564944 [DIVX])
Writing header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Writing header...
Skipping frame!
Skipping frame!
Skipping frame!
CBR audio: 16000 bytes/sec, 384 bytes/block
Flushing video frames
Writing index...
Writing header...
Video stream: 2269.486 kbit/s (283685 B/s) size: 6631154 bytes 23.375 secs 564 frames
Audio stream: 128.000 kbit/s (15999 B/s) size: 377088 bytes 23.568 secs
Encoding completed on Sun Apr 26 23:03:54 MDT 2009
I have noticed the same problem. I have generated a 2.7 .MOV file using screenflow. I copied the .MOV file to the from area on ffmpegx and told it to convert using default options. The video converts but I get no sound.
My source file data says
From MOV
Video qtrle, rgba32, 1200x800
Audio pcm_s16le, 48000 Hz, stereo, 1536 kb/s
To AVI DivX (default)
Video mencoder mpeg4, 1200x800, 940 kbps, 29.97 fps, no crop (default)
Audio mp3, 48000 Hz, 128 kbps (default)
The video looks good but there is no sound.
I have tried other combinations with the same .MOV source file
H264 with the x264 code works great with AAC sound. I am very pleased with this.
However, I have tried other formats and it looks like the sound file is generated separately if at all and not merged with the video file. You can see this at the end if the converting process.
Peter Nachtwey
H.264 video in an AVI container is generally a bad idea, as it requires a complexity that AVI was never designed for. But perhaps it was not your choice.Originally Posted by seaneroni
Sort of PCM, but with an outdated Microsoft twist. At least mencoder/mplayer seems to recognize it. The high res video contrasts the low spec (22050 Hz, 1 ch, s16le, 88.7 kbit) audio: odd combination.Originally Posted by seaneroni
The video stream and the audio stream seem to have the same duration (23.5 seconds). As far as I can tell from this log, they were both converted completely.Originally Posted by seaneroni
Audio/video Out of Synch in Converted AVI File
By Novice20 in forum Video ConversionReplies: 1Last Post: 31st Aug 2011, 02:10 -
VOB2MPG (converted MPG file has no audio!)
By sonicdeth in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 5th Jan 2010, 19:23 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 14:49 -
How to fix the lagging audio of a converted AVI file?
By PunkMaister in forum Video ConversionReplies: 15Last Post: 17th Feb 2009, 18:38 -
audio in converted file is not good
By sumeshkri in forum Video ConversionReplies: 3Last Post: 15th Feb 2008, 02:43
