VideoHelp.com Forum
Results 1 to 10 of 10
    I am trying to convert a blue ray movie with ripbot264. I have the movie in m2ts files on my hd, and ripbot finds them, but I get the following error message.
    Please help
    Thank you
    Mike
    Michael B. Smith
    Try play that video.mkv using media player classic. Does it work? if not be sure to install a newer version ffdshow.
    You can also use makemkv to make one mkv from the blu-ray main movie and then shrink it using handbrake.
    I appreciate your advice. Here is what I found out.
    It has to do with the avisynth plugins\nicaudio.dll
    It is not registered, and when I try to register it I get this message.
    Thanks for your help. Do you have any ideas?
    Mike
    Michael B. Smith
    Sorry, wrong message.
    Hopefully this one is right
    Michael B. Smith
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    tried google that error, "but the dllregisterserver entry point was not found" ? But I can't say that I found much useful info...
    Are you using winxp sp3 ? no 64bit version?
    Please help
    Thank you
    Mike
    that line 2 is just the DS command ? couldn't that be a avisynth bad installation ?
    try to remove it completely and then reinstall
    You don't need to register NicAudio.DLL
    Good Idea, but already tried that. Yes it is avisynth.
    Thanks though
    Mike
    Michael B. Smith
    I fixed the problem your posting about by uninstalling then installing Avisynth_258 along with newest Ripbot RipBot264v1.13.3
    Thanks for the info I will give that a try.
    Michael B. Smith
    I tried reinstalling everything being very careful with the versions, but still a problem. I believe now it is a problem with the framework.
    Oh well, I will look for another solution. ClownBD works very well, but still leaves me short on this project.
    Mike
    Michael B. Smith
  1. RipBot264/MP4Box error
    By netninja2001 in forum Blu-ray Ripping
    Last Post: 10th Feb 2011, 07:53
  2. ripbot264 error
    By micky46 in forum Blu-ray Ripping
    Last Post: 23rd Sep 2009, 00:08
  3. RipBot264 error in MPC crashes re-encode
    By gonzalu in forum Blu-ray Ripping
    Last Post: 6th Apr 2009, 15:52
  4. Ripbot264 error?
    By Tunfeld in forum Newbie / General discussions
    Last Post: 8th Feb 2009, 11:24
  5. DirectShowSource error in Ripbot264
    By reiter der hoelle in forum Blu-ray Ripping
    Last Post: 15th Dec 2008, 02:22
