I had the same problem. I can see that it's been a while since you asked, but since I tried to google the solution and came to this thread, I thought I'd post a solution here:
1. Go to VLC settings (ctrl+p).
2. Show all settings (bottom left corner)
3. Under audio, choose Output modules and DirectX and select speaker configuration: Stereo.
4. Save settings!
Thanks for the info. Worked great. I was a bit confounded as to how to get the setting to stick.
VlC became default audio player, some how, but I can't default 2 foobar?
By Denvers Dawgs in forum ComputerReplies: 1Last Post: 17th Sep 2011, 17:38 -
VLC audio device option issue
By vampelle in forum Video ConversionReplies: 4Last Post: 17th Sep 2010, 11:21 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:12 -
VLC Audio Device or Record 5.1?
By anonymous99 in forum AudioReplies: 2Last Post: 22nd Apr 2009, 05:09 -
Default Audio Device in VLC
By EliteMarine in forum AudioReplies: 3Last Post: 14th Jan 2008, 20:44
Statistics
Newest guides
Latest tool updates
New media comments
