Hello ... i´m new at the forum.
I am planning on converting some blurays to mkv. I hope the quality of those two will be almost identical. Wich is the best program and the best settings. Time is no problem only quality is.
Thanks in advance
Thread: Converting mkv
I think 30 gigabytes is too much for a movie... looking to reduce to 14 gigabytes.
Many movies are just around 10-20gb if you rip away extras, audio tracks, etc using tsmuxer or makemkv.
Or else use x264 encoder to shrink it, use it with a gui like ripbot264....or use makemkv and shrink the mkv using handbrake.
wich is the best if you are looking for the best quality?
dark knight is 29 gb with cutted extras
thanks in advance
There is no best.
They are the same if you use the same settings and filters and x264 version. They are all front end GUIs for x264 encoder.
Converting Left Right 3D MKV to Half SBS MKV
By TehBotolSOsro in forum Video ConversionReplies: 10Last Post: 3rd Apr 2012, 06:24 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 2nd Mar 2012, 15:25 -
Help needed for converting MKV to MKV From FormatProfile5.1 to 4.1
By y0ush4 in forum Video ConversionReplies: 13Last Post: 15th Sep 2010, 04:43 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 03:10 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 06:07
