Just tried to install 9.p04 desktop edition and got a failure
Actually downloaded above... Burn CD .. Put CD back in and got the option to "install within Windows"
Took that option, seemed to be going well, then encountered an error as below:
I suspect this may be because I have a fiorewall running??C:\ubuntu\Ubuntu.ico
04-25 11:14 DEBUG TaskList: ## Finished copy_installation_files
04-25 11:14 DEBUG TaskList: ## Running get_iso...
04-25 11:14 DEBUG TaskList: New task copy_file
04-25 11:14 DEBUG TaskList: ### Running copy_file...
04-25 11:17 DEBUG TaskList: ### Finished copy_file
04-25 11:17 ERROR TaskList: [Errno 13] Permission denied
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\backends\common\tasklist.py", line 196, in __call__
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\backends\common\utils.py", line 206, in copy_file
IOError: [Errno 13] Permission denied
04-25 11:17 DEBUG TaskList: # Cancelling tasklist
04-25 11:17 ERROR root: [Errno 13] Permission denied
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\application.py", line 55, in run
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\application.py", line 125, in select_task
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\application.py", line 193, in run_cd_menu
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\application.py", line 117, in select_task
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\application.py", line 155, in run_installer
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\frontends\win32\frontend.py", line 137, in run_tasks
04-25 11:17 DEBUG TaskList: New task check_iso
04-25 11:17 DEBUG CommonBackend: Searching for local ISO
04-25 11:17 DEBUG CommonBackend: Could not find any ISO or CD, downloading one now
04-25 11:17 DEBUG TaskList: New task get_metalink
04-25 11:17 ERROR TaskList: Cannot download the metalink and therefore the ISO
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\backends\common\backend.py", line 482, in get_iso
File "Z:\home\evan\bzr\wubi.trunk\build\wubi\files\lib\ wubi\backends\common\backend.py", line 326, in download_iso
Exception: Cannot download the metalink and therefore the ISO
04-25 11:17 DEBUG TaskList: # Finished tasklist
It has created a C: ubuntu directory containing three directorys and one icon and one uninstall prog (699mb)
Results 1 to 1 of 1
Thread: 9.04 installation problems
The electronic components of the power part adopted a lot of Rubycons.
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 21:45 -
By Finnytribe in forum ffmpegX general discussionReplies: 9Last Post: 20th Feb 2009, 12:11 -
ffmpegX Installation problems....
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 01:32 -
AllToAVI installation problems
By T_virus in forum Newbie / General discussionsReplies: 0Last Post: 25th Dec 2007, 09:28 -
.NET installation problems.. I must'uv been crazy to bother!
By vhelp in forum ComputerReplies: 36Last Post: 15th Oct 2007, 09:47
