Hi
When I add an extra file folder to a DVD, my player attempts to play the contents as a slide show rather than play the video_ts folder. Is there a folder name I can use in which the player will not recognize and will simply play the video?
Thanks in advance
Thread: Adding extra data folders to DVD
The DVD player should only see the video_ts folder and ignore anything else.
You structure should be
video_ts
audio_ts (optional in most cases, but included for completeness)
data can then be stored in any other folder at this level, or as files at this level.
I suspect that you are burning the disc as data, not as a DVD Video disc, which is confusing your player. What are you burning with ?
hi guns1inger
I burn with imageburn. The DVD plays fine in my Philips and LG, but not in my Samsung. The Samsung seems to prioritize the additional folder and plays the contained pictures as a slide show. Do you know the name of the folder that some softwares create when they add additional folders on DVD?
It can be called anything at all. There is no standard for external content.
When you burn, do you use Build mode, and select the Video_TS folder ?
Are you using the latest version of Imgburn ?
I have been adding data folders to a recent project. I burn with the current version of ImgBurn using "Build Mode", and I have it set up to add an AUDIO_TS folder. I remember reading here that it is important to select the VIDEO_TS folder first, and data folders last to ensure compatibility with all DVD players. It seems to work.
Selecting the Video_TS folder first tells Imgburn that you are creating a DVD Video file. The latest version double checks to make sure you have the correct settings and changes them if necessary. After that you can add what you like. I have created projects with multiple folders of data - MP3 versions of the sound track in one folders, still images in another, and supporting documentation in pdf format in a third. All played back with no issue on multiple players.
Hi Again
It appears your right guns1inger. I just let TMPGenc create its own extra folder with its slide show feature. It simply used PICTURE as the addition folder....nothing special. The problem I'm having must be a isolated issue with Samsung. The imageburn I use is the latest and I did add the video_ts/audio_ts folders first.
any more thoughts?
Adding extra files to DVDs
By kinglerch in forum Authoring (DVD)Replies: 2Last Post: 21st May 2010, 12:59 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 13:48 -
.spotlight-v100 folders/adding new firmware
By danielmak in forum MacReplies: 7Last Post: 10th Oct 2009, 00:46 -
Malware running from Application Data folders - can be prevented?
By Ai Haibara in forum ComputerReplies: 16Last Post: 25th Aug 2009, 10:35 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 17:17
