Hello,
I have a Ubuntu Desktop server, Quad Core Q6600, 4GB RAM. I am trying to run meGUI using Wine, but it doesn't really run.
I tried running the meGUI.exe via. Wine, but the exe doesn't run. It says "Starting meGUI" in task bar, but it never loads.
Anyone knows how to run meGUI on Ubuntu?
Thanks!
Results 1 to 12 of 12
"Required tools:
Microsoft .NET Runtime 2.0"
Maybe you have to run it inside a virtual machine. Not sure if Wine handles the .NET runtimes.Even a broken clock is right twice a day.
So, you mean install VMWare and then do it?
VMWare, Virtualbox... either one should work.
I'm not an expert on Wine (or even a knowlegable user). There might be a way with Wine but I don't know it. I'm just offering other options. If Wine doesn't work, a windows virtual machine almost certainly will.Even a broken clock is right twice a day.
Yea, trying VMware with Windows 2008 or XP :P.
let us know if it works out.
You could try to install the windows version of mono (.net substitute) and then install megui both in wine.
When starting new programs in wine the best way is to start from command line terminal.
sudo wine "/home/user/wine/drive_c/program files/your prog.exe"
Or something like that. I'm going from memory here as I'm booted in win right now. When running from terminal you will be able to see any errors that pop up and then you will know what to go after to fix.
This is a good practice for running any new programs in linux not just those in wine. A tip I got from disturbed1 that has helped me a lot.Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
I already have mono-service 1 and 2 installed, but no help. On the command line it says, "wine is not owned by you". I have no idea what that means.
How do I run a wine application once I've installed it?
Also the mono service I mean is the windows version. Install it with wine. I have no idea if this will work or not as I haven't tried to use a .net program with wine but I think I read somewhere that it may work.
If your machine has the resources to run a vm then that may be the easiest way to go.
sometimes wine works better when consumed...Donadagohvi (Cherokee for "Until we meet again")
Current versions do not work according to all the developers (some ancient builds will work apparently), if you figure out a way, I'm sure many people will be happy
In the meantime, you can use avidemux in linux for encoding (incl. x264)
You can use the avsproxygui that comes with avidemux ,
or avsfilter
http://avsfilter.berlios.de/index.html
http://forum.doom9.org/showthread.php?t=143227
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video StreamingReplies: 2Last Post: 19th Apr 2012, 16:25 -
Powerpoint won't run in Wine
By Webster in forum LinuxReplies: 2Last Post: 25th May 2011, 04:17 -
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18 -
Linux Ubuntu 8.04 LTS Desktop, How to Recover or Reset Admin account pass
By retroborg in forum ComputerReplies: 2Last Post: 3rd Oct 2008, 06:27 -
Dual Boot Ubuntu Err 21 on PC with XPPro on RAID0 Drive and Ubuntu on eSATA
By videocheez in forum LinuxReplies: 32Last Post: 11th Jun 2007, 00:51
