I've been using StaxRip for creating MKV files for at least a month now, I personally like the quality of the MKV files over Ripbot264 and Handbrake. My only issue is that StaxRip uses DGIndex for audio processing that creates audio that is out of sync.
I have discovered a work around, what I do is use the "Add existing file" setting and this tells the program to use the original audio file without any processing whatsoever.
What I would like to know if anyone has figured out a way to use the other audio settings without audio sync issues? If so, what do you recommend?
Results 1 to 1 of 1
Do unto others....with a vengeance!
Video/Audio out of sync after using StaxRip
By supernano in forum DVD RippingReplies: 1Last Post: 23rd May 2011, 23:30 -
Increasing fps in Staxrip encoding mkv files.
By Jayyflyy in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2011, 14:05 -
MKV files.... audio out of sync. What is......
By forest.lawn in forum Newbie / General discussionsReplies: 6Last Post: 11th Oct 2010, 11:04 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
Audio in MKV files goes out of sync when demuxed
By carlmart in forum Video ConversionReplies: 11Last Post: 29th Oct 2009, 06:18
