VideoHelp.com Forum
    Hello,
    Have followed instructions at http://www.ffmpegx.com/download.html#metadata to the letter.
    When I drop the folder called <flvtool2-1.0.6> into Terminal and hit Return I get the message:
    Last login: Mon Mar 16 16:36:07 on console
    james-computer:~ James$ cd/flvtool2-1.0.6
    -bash: cd/flvtool2-1.0.6: No such file or directory
    1. Why is the message 'No such file or directory' coming up and
    2. what should I do install FLVTool2 successfully?
    Thanks for your help!
    Visioner.
  2. Explorer Case's Avatar
    There should be a space character after cd, to separate the cd command (change working directory) from the parameter (the path to the folder).
  1. Replies: 26
    Last Post: 4th Jan 2012, 07:49
  2. Help with metadata when converting to FLV using flvtool2?
    By Sharon M in forum ffmpegX general discussion
    Last Post: 27th Jan 2010, 16:23
  3. HELP downloading flvtool2!!!
    By ajeanette in forum Mac
    Last Post: 22nd Oct 2009, 12:44
  4. FLVtool2 installation problem
    By linea in forum ffmpegX general discussion
    Last Post: 15th Dec 2008, 12:09
  5. FLVtool2 doesn't install correctly
    By chaosmoon in forum ffmpegX general discussion
    Last Post: 12th Feb 2008, 19:25
