Hi I am trying to convert old DVDs to mkv format. I also want to upconvet them to 720p resolution. I tried handbrake but It does not improve the resolution (unless I am missing some steps). Is there any application that I can use to do this. I am using network media tank and watching on 133" screen with 1080p projector, so getting 720p or higher resolution is priority. Thanks![]()
the only thing re-encoding dvds to 720p can do is make them look worse.
every time something is encoded it loses video quality no matter what is used to do the encoding.
get a dvd/blu-ray player that upscales in hardware if you must have 720p.
Use MakeMKV to remux the DVD into an MKV file. Let the player do the scaling. You won't be able to do significantly better with software.
How Can I Convert DVD to HD 1080p resolution as easy as HD 720p
By hd hackerz in forum DVD RippingReplies: 5Last Post: 11th Jan 2011, 03:54 -
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 10:16 -
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 07:17 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 09:57 -
Convert .mkv to .avi at HD(720p) resolution
By Boby4CPO in forum Video ConversionReplies: 15Last Post: 4th Dec 2009, 13:58
Statistics
Newest guides
Latest tool updates
New media comments
