VideoHelp.com Forum
    Hello,
    I have a DVD with hard drive that I use to watch TV. I pause it, then I watch 5 min after so I can skip all the commercials. Anyway, here is my problem. When I push play and start to watch the program, I see a ghost image in forms of subtitles and the like. I believe it is the program in real-time. It is very frustrating to have another subtitle in the middle of the screen.
    What could be the problem? I have connected the RGB cable from Ext 1 to Ext 1 in the TV. Could the RGB be broken, or do you have another idea what it could be?
    By the way I have no satellite receiver, the TV I use is equipped with DVB-T.
    Johansson
  2. Member Ozzyjim's Avatar
    Gday,
    I have had the same problem on a Panasonic DMR-ES10 (no hdd) when watching live tv. Try connecting it up via different inputs/outputs and see if that helps, It worked for me.
    James.
  1. JVC SR-DVM70 160GB part of the HDD image needed
    By dvd4met in forum DVD & Blu-ray Recorders
    Last Post: 20th Aug 2010, 19:31
  2. Replies: 11
    Last Post: 24th Aug 2009, 13:24
  3. Replies: 6
    Last Post: 9th Oct 2008, 12:38
  4. Restore Ghost Image Problem
    By bevills1 in forum Computer
    Last Post: 1st Apr 2008, 13:03
  5. Is it possible to capture the image from plasma and copy directly to HDD?
    By Steve237 in forum Newbie / General discussions
    Last Post: 22nd Jul 2007, 13:35
