ok my vlc media player has been acting up. when ever im watching a movie the player for no reason switches to 4:3 ration or 16:9 or makes the volume loud or quiet. its really weird what do you recommend? im running on a vista system
Thread: VLC Media player problems
We don't stop playing because we grow old; we grow old because we stop playing.” (George Bernard Shaw, 1856-1950)
What version of VLC? Have you tried uninstall and reinstall? (Delete the settings file when reinstalling) I suspect the settings file is corrupt.
i reinstalled the new version and every time im turning the volume up it randomly goes up or down also when im watcing the movie it will randomly change the aspect ration if i touch the mouse pad on my laptop
I haven't seen that yet. Make sure your display driver and mouse driver are current.Originally Posted by romanstopmeRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Did you choose to delete the existing VLC settings when you reinstalled?
yeah i did and it seems to do that every time when i turn up the volume
Does the volume randomly and wildly change (considerably), or is it more of an equalizer type of effect?
I've spent some time looking through the VLC settings, and I'm not sure if there are any that could be causing wild shifts in volume and aspect ratio... more so, as you did say you've reset the settings at least once. It might be a good idea to ask this question on the VLC forums as well (http://forum.videolan.org/ ); maybe the VLC devs will have a better idea what might be happening.If cameras add ten pounds, why would people want to eat them?
sweet but i think its more of a problem with my computer then the program it self ill try to reinstall vista cuz i haven't done that yet on my lap top
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 6Last Post: 20th Mar 2012, 10:22 -
display size between windows media player and VLC player
By kool_k in forum Software PlayingReplies: 4Last Post: 6th Aug 2011, 15:18 -
vlc media player record problems
By deanst2 in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2011, 08:58 -
VLC Media Player - Video Problems After Downloading Streams
By Simmons in forum Video StreamingReplies: 1Last Post: 14th Apr 2011, 03:44 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16
