Source: DV from my Sony TRV-9, captured with WinDV
Destination: deinterlaced H.264 video file with aac audio
After spending considerable time on this subject, I've found a great solution that produces "small" (about eight percent of the original) video files with excellent quality. The only negative is the time it takes to encode, but that is not an issue with me. On a quad-core at 2.33 GHz, encodes take about 16 hours per hour of DV source. I've got 45 hours of source video to convert in my leisure time.
Basically, I followed this guide for upscaling SD to HD, but left out the upscaling part;
http://www.dvinfo.net/conf/992266-post14.html
After digesting that, I ended up with an AVISynth scripts look like this;
SetMTmode(2,0)
AVISource("DV28.01-06-22_01-08.17.avi", audio=FALSE)
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\removegrainsse3.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\repairsse3.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\nnedi.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mvtools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools-26.dll")
Import("C:\Program Files\AviSynth 2.5\plugins\tempgaussmc_beta1.avs")
ConvertToYV12(interlaced=true)
AssumeBFF()
TempGaussMC_Beta1(EdiMode="NNEDI")
SelectEven() # bc the interlacer doubles the framerate
Lanczos4Resize(720,528,0,5,720,469)
I'm feeding it to MEGUI and using the Unconstrained-2pass-HQ profile and 2000kbps. My movies are 720x528, square pixels.
Hope this can help someone looking for the same thing. I stumbled on it by accident.
Results 1 to 16 of 16
ok...
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Cool, I was wondering if my post was OK, thanks for clarifying.
16times looks for me terrible slow.Originally Posted by bpoe
I am converting dv-avi to MP4 (+aac) with an average of 5times on my 'old' pc (P4 of 2004). So 10 minutes of video gives 50 minutes of encoding.
I do this with the following setup:
DirectShowSource("clip.avi")
TDeint(mode=2) #Deinterlaces the clip
Spline36Resize(544,306) #Resize the clip
Why are you using all these filterings (dll),...?
The TempGaussMC_beta1 script requires those other plugins. The filtering it does helps with low-light scenes in minimizing noise, but overall, it seems well known that the TempGaussMC_beta1 script produces nice/rich output. I've done lots of comparisons with other methods/deinterlacers/etc, and I have to agree.
You need to remove noise, both in-frame and temporally, for quality H.264 work. Otherwise it looks like crap. You also need to do a proper deinterlace, not some nasty half-assed drop-frame method.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
How can you say that lordsmurf? TempGuassMC_beta1 seems to be one of the better deinterlaces available. See this post:
http://forum.videohelp.com/topic354397-30.html#1877202
It use motion compensation and it looks good to me. But this deinterlacer is really slow and thsat is why the encoding is so slow. I might be worth rendering it to lossless format like lagarith before doing the 2-pass encoding.
I would not consider this to bee a "nasty half-assed drop-frame method". Of course it would be better to keep the double frame rate but since the destination in this case is deinterlaced h.264 with small video size I think it may be acceptable to drop the framerate from 60 fps to 30 fps (NTSC) or 50 fps to 25 fps (PAL). And the script does include denoising also.
The 16 hours can easily be reduced to under 10 using CRF. And why even limit yourself to 2000kbps when the video can look so much better with a bit more bitrate, or just as good with so much less bitrate depending on the source? Inefficient encoding.
As well, I hope you're archiving this, maybe precious and unrecoverable, DV source. You are going to lose alot of quality with this method and have severly hurt your high quality options for other playback options in the future.Can I get you to clarify this? All my low-bitrate x264 encodes, although "watchable", look like crap on a big screen TV so I gave up on it. Yeah, I can increase the bitrate of x264 encodes, but at that level, for high quality, there are better options.Originally Posted by lordsmurf
Still interested in trying something new for low bitrates, or even to be proven wrong of my belief that x264 is worthless other than for mobiles or Internet distribution.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Like what? Can you share your "better" options? Your statement implies that there is something out there that provides better compression i.e. more efficientOriginally Posted by PuzZLeR
Not sure what you mean? If you "shrink" a blu-ray source, what format gives you the best quality, best detail & grain retention at a given bitrate? In my tests - and tests done many others - videos encoded by x264 by far.Originally Posted by PuzZLeR
Hey Poison,
I meant to answer in that other thread, but it was on VP7 and I didn’t want to hijack it. Was going to answer it, but well, then it got old. :P Nevertheless my friend, you deserve an answer.Well, it’s not so straight-forward.Originally Posted by poisondeathray
Assuming SD, among compressed formats with bitrates under 1000kbps-1500kbps there is no other that can beat x264. It totally rules the world here. No argument.
But all it really produces at this level for most sources is something “watchable”, and "watchable" is not synonymous with "high quality". Although better compression, it's still blurry, smeary and looks hideous on the big screen.
And the compression advantage of x264 is not so linear - quality benefits fade quickly with respect to bitrate compared to other formats, even to the point where it starts to dip below them in the curve.
For "high quality" video you need to raise the bitrate for x264 (like any other lossy format). This invites other, and (much) better, options.
At "realistic" bitrates of 3000kbps-5000kbps I get much better encodes with MPEG-2 using CCE (as well as with DivX/Xvid) and they look very nice on the big screen - with the same source/script. But the blur/smear stuff is still there, albeit in a somewhat lesser form, with x264. It never really goes away until mega bitrates like 6000kbps and more.If you want very low bitrates, again, x264 is King here. But if you want something more professional looking than a “blurry”, or “smeary” video you’d settle with, then you need to raise the bitrate, and that invites, again, other better options once more like DivX, Xvid and MPEG-2 (such as with a good MPEG-2 HD encoder like TMPGEnc, etc.).Originally Posted by poisondeathray
Yeah, I know about the AQ thing optmized over Haali's previous patch, the negative alpha/beta thing and other artificial complexities, but all they do is balloon the bitrate, defeating any purpose of using x264 in the first place.
I feel that x264’s secret is a “smart blur” subroutine somewhere optimized for low bitrate encoding and due to the fact that it takes forever to encode, does not play on DvD, and a pain to edit, and worse than others at high bitrates, I can’t help but come to the conclusion that other than mobiles and online distribution it’s completely usesless when it comes to high quality formats.
The “Big Show” in my opinion, which is what I want, is the big screen, not with mobiles, or “distributed” Internet content. This is why I dropped x264.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
(I apologize for the thread hijack, this was on DV originally...)
Puzzler - I have to disagree, unless you were referring to interlaced content; x264 is still in it's infancy in regards to interlaced encoding.
I am talking about the big screen , progressive, high quality ie. blu-ray. I have to assume you were either using an old build or bad settings in your testing. I suggest you repeat your tests with a high quality blu-ray source, something that has a lot of film grain and detail.
I know exactly what you're talking about, historically the oversmoothing was the biggest issue of the older x264 builds and that still plagues other h264 encoders (like mainconcept). While this type of discussion may have been more frequent a few years ago, this is the first time I've heard of someone suggesting MPEG2 or XviD provides better quality over a modern x264 buildBut if you want something more professional looking than a “blurry”, or “smeary” video you’d settle with, then you need to raise the bitrate, and that invites, again, other better options once more like DivX, Xvid and MPEG-2 (such as with a good MPEG-2 HD encoder like TMPGEnc, etc.).
The modern x264 builds are a different animal. Even the fine details are preserved at lowish bitrates with x264 (fine film grain). Take 300 the movie for example (an example of "dancing grain"), and do some testing at various bitrates, I bet you will be surpised. Take any high quality blu-ray source and I am certain x264 will do a better job than MPEG2 , VC-1, VP7 or another other format at the same - and usually a much lower bitrate. And I mean in terms of retaining the detail and grain - something h.264 encoders have historically failed at.
The visual quality advantage of x264 isn't just subjective or my lonesome opinion - look at the PSNR and SSIM objective testing: the MPEG2 numbers don't even come close! The results by x264 are visually lossless at a much lower bitrate than MPEG2 for any source, frame size, etc.
For all types of content, MPEG2 usually requires 1.4-1.5x the bitrate to look equivalent to the x264 encode, and not just at lowish ~1Mbps bitrate scenarios or SD scenarios. This relationship extends well into the 1080p HD / blu-ray quality area. I realize the relationship isn't linear, but on some material, MPEG2 never reaches transparency to the source even at unlimited bitrates! (Take the classic Touhou lossless footage, for example)
I agree with the long time to encode and pains to edit, but in terms of quality x264 is unmatched at equivalent bitrates. It provides better compression => this implies better quality at the same bitrate, or similar quality at a lower bitrate. I have yet to see 1 example where MPEG2 reaches transparency to the source earlier (ie. at a lower bitrate) than x264. If you have 1 example, please post it.I feel that x264’s secret is a “smart blur” subroutine somewhere optimized for low bitrate encoding and due to the fact that it takes forever to encode, does not play on DvD, and a pain to edit, and worse than others at high bitrates, I can’t help but come to the conclusion that other than mobiles and online distribution it’s completely usesless when it comes to high quality formats.
puzzler said: >As well, I hope you're archiving this, maybe precious and unrecoverable, DV source. You are going to lose alot of quality with this method and have severly hurt your high quality options for other playback options in the future.
I have seen the results - while its not the quality of the DV source, the quality IS excellent and "close" to the original. I do study the output frames and compare to original frames, and analyze motion. That is my whole point in my original post, this produces excellent quality video from DV source. I've done trials that show I could increase the bitrate and get marginal improvements, but the 2k is fine. I'm archiving the DV originals.
As for the 16 hours, yes i could cut it down by first encoding to uncompressed and then do the 2-pass h.264 (i've done it), its just more convenient to point MEGUI at the .avs and que-up a 2pass and come back the next day.
My comment was in reference to the post by laurentje.Originally Posted by ronnylovAnswers to Common Video Questions:
All depends what the definition is of 'crap'. I have made several tests with all kind of filtering and it is sometimes hard to see the quality difference with or without all those filters (at low resolution 400x300). And then of course you have to spill 16 h for 1 h of video.Originally Posted by lordsmurf
The resolution is very important, but perhaps we are on off-subject.
Deint(mode=2) is that a "some half-assed drop-frame method"? I was not aware of.
Crap = noise not related to the image, such as blocks and artifacts.
Please spare me the "my definition" baloney. There are people that find scat porn erotic, but 99.9% of the world would also consider that unacceptable garbage. The 0.1% (or less) that define it as acceptable should be wholly ignored.
Noise is noise, at any resolution.Answers to Common Video Questions:
Yes, but if there is no noise, then those filtering is not necessary. All this filtering costs a lot of time and money...Originally Posted by lordsmurf
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
.264 Conversion
By thunderclap82 in forum Video ConversionReplies: 4Last Post: 11th Mar 2010, 17:48 -
Looking for H.264 conversion help
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 24th Nov 2009, 05:19 -
H 264 conversion
By Russo in forum Video ConversionReplies: 95Last Post: 8th Oct 2009, 16:38 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 06:47
