VideoHelp.com Forum
  1. Hi,
    I bought a PAL DVD of a Soviet-era film, and noticed some frame blending, sporadically in stretches.
    Attached is a clip as an example.
    Frames 0-52: no blending
    Frames 53-120: blending
    Does anyone know why these frames are blended? Is there a mistake, or is there some other reason?
    I just find it a little sad, because IMHO the film quality is otherwise decent, and the blending takes away from it.
    Thanks, I am just really curious.
    Chipsndukes
    test1.demuxed.zip
  2. It was deinterlaced. Both fields of the blended frames are also blended. It's hopeless.
  3. Hi manono,
    Thanks for taking time and looking at the clip. Yes, I did sort of want to remove the blending, and have seen it done with VCD-like files:
    http://avisynth.org/mediawiki/Removi...frames_on_vcds
    This case is tougher because no original frames are present, the blends are always in stretches.
    To answer my own question regarding the blending, I would say it was a cheap way to adjust framerate without having to adjust the audio.
    Chipsndukes
    Shoddy work is all this is.
  1. Add pictures before DVD PAL film (problem)
    By saqu in forum Authoring (DVD)
    Last Post: 15th Nov 2010, 16:17
  2. Replies: 14
    Last Post: 27th Apr 2010, 16:14
  3. Adjusting frame rate on a slient film
    By fred3f in forum Editing
    Last Post: 8th Nov 2009, 18:44
  4. frame blending with mencoder
    By spaceshotfever in forum Linux
    Last Post: 14th Feb 2009, 12:46
