VideoHelp.com Forum
    Hi,
    I need some guidance on 1)what would be the best bitrate/resolution of an .avi (movie) to watch on a 32"/37" LCD TV, in a near-DVD quality and 2) would converting a DVD to avi, by using Auto GK at 75% quality provide good results for the above TV?
  2. 2) would converting a DVD to avi, by using Auto GK at 75% quality provide good results for the above TV?
    Yes. And there's no answer for the first question, as one bitrate does not fit all. Much better is a quality encode such as the AutoGK Target Quality 1-pass encodes, because then it uses the bits it needs to achieve the desired quality.
  3. Member edDV's Avatar
    As manono implied, the higher the quality the source, the more it can be compressed with good quality. Another factor is the amount of motion present in the source. Most film based movies were shot with careful control of motion. Home videos are often jerky with uncontrolled motion. The latter requires much higher bit rates to avoid motion artifacting.
    http://www.kiva.org/about
  4. Hi
    As said above the target quality setting is good for getting pretty consistant result. If storage size is not an issue for you then this is the way to go. As for what % to use, then this is something you might want to test out by ripping a few chapters from different movies and then running autogk on them at different % settings and see what works for you.
    Also I tend to let autogk work out what res to use and you might want to consider the audio side as you can keep the DVD original audio or MP3 it for a smaller filesize.
    All I've done is try and test. The only thing I'd try to avoid is getting into circles of comparing one encode against another and another until you get so fed up not making a choice that you loose all enthusiasm to do what you planned to do in the first place. I've been there many times.
    Daz
    Why not just watch the DVD and let either the TV or the DVD player do the upscaling for you?
  1. Replies: 2
    Last Post: 13th Jan 2009, 11:50
  2. Replies: 11
    Last Post: 18th Oct 2008, 09:00
  3. watching avi from my pc to toshiba lcd hdtv
    By goo2 in forum Software Playing
    Last Post: 21st May 2008, 20:19
  4. Resolution/bitrate for small LCD
    By jkleslie in forum Newbie / General discussions
    Last Post: 27th Feb 2008, 13:16
  5. Watching HDV footage - 1080i CRT vs. 720p LCD
    By JohnnyMalaria in forum DVB / HDTV
    Last Post: 21st Feb 2008, 01:29
