VideoHelp.com Forum
    Hi there!
    I have an .avi file with two files aside: .idx and .sub
    The .idx contains two languages: 1 and 2
    I want to build a DiVX file containing the subtitles in language #2.
    I mean with the subtitles integrated to the video file not in a separate file.
    How do I proceed?
    Most complicated for me is the use of the Filter Tab...
    I did four different and unsuccessful encodings...
    Grrr...
    Many thanks in advance for your valuable help!
    Gerard
    Thanks for replying!
    I put the AVI + .idx/.sub subtitles in a MKV container and burnt a DVD with Toast.
    My DVD Player doesn't recognize MKV...
    Then I did what you suggested in your post in late January, using ffmpegX to transcode the MKV to AVI with burned-in subtitles.
    I did different unsuccessful tries (settings in the Filter Tab) with no results at all..
    Could you elaborate and give me some explanations about your suggestion:
    "...you can encode to DVD using the DVD mpeg2enc preset with Decode with mplayer activated. That seems to be the only setting that supports idx/sub for input in ffmpegX."
    How do you encode to DVD?
    In ffmpegX?
    Regards,
    Gerard
    In ffmpegX?
    Regards,
    Gerard
    Not sure how much more specific one could get. He says to use the DVD mpeg2enc preset. Ffmpegx has presets. Use the DVD mpeg2enc one. Then select "decode with mplayer " instead of, say, "decode with quicktime." If this is still somehow unclear, I suggest spending a couple of minutes reading the ffmpegx documentation. It's pretty well written.
  1. Replies: 5
    Last Post: 4th Mar 2011, 02:25
  2. ffmpegX jumps to "finished" crashes computer, lost progress.app
    By jegler in forum ffmpegX general discussion
    Last Post: 2nd Jun 2008, 19:53
  3. lost audio
    By chelseamick in forum Newbie / General discussions
    Last Post: 25th Jan 2008, 10:54
  4. Lost Sound
    By airgunforum in forum Editing
    Last Post: 22nd Nov 2007, 10:40
  5. Lost Videos
    By jackowens in forum Newbie / General discussions
    Last Post: 18th May 2007, 09:44
