VideoHelp.com Forum
  1. I am trying to use an older DC30 card for Hi8 capture.
    Quality is outstanding!
    However, colors are all wrong!
    Blue backdrop for bluescreen is green, skin tones do not exist, people are blue-gray, etc.
    Captures with the WinTV are good color wise but not as sharp as the DC30
    Here is my system:
    Windowz XP Pro, SP3
    Asrock 775DUAL-VSTA mobo
    E2180 CPU @ 2.70ghz
    2 gig ram
    EVGA GT9600 1gig vid card
    XPLOSION 7.1 sound card
    WinTV GO! capture card using btwin drivers
    DC30 using aftermarket drivers & AMCAP software,( tried Pinnacle Studio 12, Sony Vegas 8 Pro, same problems!)
    Generic Firewire card
    Do I have a bad card or is something else causing this problem, other drivers, cards, etc.?
    Please advise as I have need for on-going very hi quality Hi8 captures!
    Regards,
    jaybird
    Since you're doing an analog-to-digital capture, you could always put a proc amp, TBC, or other video processing device between your Hi8 device and the capture box. (Sima used to make a consumer-level color corrector. You could look around for one of those.) Otherwise, see if there is some preset that you are overlooking in the capture software. I don't use AMCAP, so I don't know if it allows you to tweak the hue and other levels. But it seems to me that you could alter the color with whatever capture utility you have.
  1. video capture problems - HV20 camcorder is controlled but no video capture
    By chebowitz in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Feb 2010, 10:49
  2. upgrading to DC30
    By jmacky in forum Authoring (DVD)
    Last Post: 25th Oct 2009, 21:18
  3. Problems with video capture
    By DrRST in forum Newbie / General discussions
    Last Post: 11th Nov 2008, 21:48
  4. Problems with capture software
    By jubbely2 in forum Capturing
    Last Post: 29th Aug 2008, 12:47
  5. MJPG miro DC30 best bitrate VHS to DVD
    By dav75 in forum Capturing
    Last Post: 13th Sep 2007, 05:36
