VideoHelp.com Forum
Thread: Burn problem
    Hi everybody!
    I'm from Italy, sorry for my english, I hope u understand me.
    I have a problem and I can not get out ... although I believe it is Vista ...
    Basically, I just bought a SONY VAIO Notebook VGN-NS21S.
    Just brought home I formatted and installed all the drivers for a clean system.
    Drive is Pioneer dvd-rw dvrtd08
    SO vista SP1 with all updates.
    Now the problem is that with any burning software (Nero, Ashampoo etc..) I can not burn.
    The burning part and hangs approximately 50% after 10-15 and the recorder I eject the DVD and the software tells me write failed.
    By VISTA RECORD TOOL WORKS!
    Before formatting, and then bundled with the system to work. I tried with an external firewire burner, same problem.
    Log in attachment.
    Do you have idea?
    Thx!
    Ciao!
    log.txt
  2. Member Dv8ted2's Avatar
    How fast are you burning? The write speed may be faster than the disc can handle.
    Believing yourself to be secure only takes one cracker to dispel your belief.
    Hi!
    2x
  4. Member Dv8ted2's Avatar
    Increase the burning speed.
    Same result, burn process failed
  6. Member Dv8ted2's Avatar
    Try a different batch of discs
  7. Member Krispy Kritter's Avatar
    Try again with Nero and if it fails, post the error log.
    Google is your Friend
    In attach...
    log.txt
  1. Imgburn problem when I burn xbox game before now could not
    By Ryanzin in forum Software Playing
    Last Post: 14th Jan 2012, 20:02
  2. Problem w burn for Mac
    By allakantralla in forum Newbie / General discussions
    Last Post: 25th Dec 2011, 19:12
  3. Windows 7 RC burn problem...
    By acmky in forum Computer
    Last Post: 11th Aug 2009, 16:20
  4. Problem with converted AVI burn to DVD
    By lotususer in forum Video Conversion
    Last Post: 10th Jan 2008, 02:54
  5. problem to burn
    By Chris 67 in forum DVD Ripping
    Last Post: 23rd Jul 2007, 12:34
