Capturing VHS tape footage to HDD via a DVD-Ram Recorder. Results are OK, but I notice that there are "jaggies" on lines (Eg building roofs, railings, wires etc etc) that are almost horizontal. Obviously there is something wrong with the horizontal or vertical resolution but I'm not sure what, or how to fix it. I've tried resizing first the Width, then the Height, using the Resize filter in Virtual Dub, but it doesn't seem to make any difference.
So.......Any help would be greatly appreciated.
Zen
Sounds like interlace. Try playing it on a TV and you won't see them. Computers use a progressive type display and those lines will show unless you use a software player that can handle interlaced video correctly. VLC and others can.
But I would try a TV set. They use interlaced by default. So you likely don't have any problem other than viewing the video with the wrong software player or not turning on the players interlace settings.
And I'm assuming the video is MPEG-2, otherwise if you are converting to AVI type formats like Divx/Xvid, you might want to run them through a deinterlacer first.
EDIT: If interlace isn't your problem, post a screen shot of what you are seeing. Or a short video clip.
Ripping DVD via Ripbot = Jaggies?
By Ka0tiK in forum DVD RippingReplies: 1Last Post: 23rd Dec 2011, 07:35 -
DV jaggies in Final Cut Pro
By phil.good in forum EditingReplies: 9Last Post: 23rd May 2010, 09:10 -
How to encode 264 without aliasing (jaggies)
By vertigoanduminas in forum Blu-ray RippingReplies: 21Last Post: 9th Feb 2010, 18:47 -
Replacing glitched audio in DVD transfers from VHS tapes.
By ramrod1234 in forum AudioReplies: 4Last Post: 17th Nov 2009, 15:11 -
Project HD Image files without jaggies
By tram in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2009, 12:37
