i keep getting this pop up message from windows saying that my virtual memory is too low and windows is increasing my paging file system?what can i do to stop this,add more ram?
Thread: virtual memory too low?
248mb is way too low, I would definitely add more ram, or better yet, just upgrade your system
You can increase your page file manually as a temporary measure (it uses the hard drive as virtual memory, but the hard drive will thrash as it swaps). Right click my computer, advanced tab, settings under performance category, advanced tab, virtual memory. You should set it so the min & max size are equal, so it doesn't constantly re-size and cause more performance issues. I would set it at least 2-4GB on your system if your listed specs are correct
You can also reduce consumption by closing unnecessary programs and services
If your system specs are correct then you could sure benefit from more ram. If that is not an option but you have a small spare hard drive you can pop that in to your pc and change your page file to that hard drive. I did this once on an old system that I had a long time ago that only had 384mb ram. I put a spare 4gb hard drive in and used it as a dedicated page file drive. It sure helped.
More ram would be more efficient though and you can find old ram on ebay for decent prices.Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
In general, setting the size of the swap file to about 1.5-2.5 times the size of your physical RAM.
256mb, assuming 8 used by onboard video isn't bad but consider getting an addon gpu of some kind so that system memory is for system only.
Also: http://support.microsoft.com/kb/314834 ... about clearing the swap file on shutdown ... means system always starts with a clean swapfile.
And: http://technet.microsoft.com/en-au/s.../bb897426.aspx ... pagedefrag.
Issues with low memory while rendering Vegas 11
By magic612 in forum EditingReplies: 28Last Post: 8th Dec 2011, 19:49 -
Will not render in Vegas says system is low on memory
By kILLDR3n in forum EditingReplies: 7Last Post: 26th Mar 2010, 12:44 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Sony Vegas 8 low memory error
By mouseclubhouse in forum EditingReplies: 13Last Post: 7th Aug 2008, 17:18 -
Xvid4PSP making Windows give Virtual Memory low message
By godfist314 in forum Video ConversionReplies: 5Last Post: 22nd Jul 2008, 14:09
Statistics
Newest guides
Latest tool updates
New media comments
