Hello,
Only me again.
I have created a avi movie and i followed the instrutions on how on how do this and add subtitels as its in Korean.
But the subtitels are not showing and are not a option to turn them on on my divx player its greyed out.
Have i done something wrong ?
I added in the filerts Tab the .Sub file and previewed and they showed but once this encoding had finished no subtitels :O(
I have a .Idx file as well if that helps ??
I was thinking i changed the outfile name should i have made the .Sub the same ?
Many Thanks in advance for the help.
Fez
Thread: No subtitels !?
What do you mean when you say "divx player"? Is this a standalone DVD player (ie. Pioneer, Samsung, etc.) Or some software player on a computer?
Some standalone DVD players that support Divx only support Latin and Cyrillic character sets and in external subtitle files. If you have such a DVD player, you will have to hard code your Korean subtitles. If you are using a software player, maybe try using VLC.
The few standalone Divx players I've had experience with will only support subs in .srt format. If you are talking about a standalone player like that, then you won't see any Korean subs. In that case, you may have to burn the subs into the video, forcing a re-encoding (and quality loss).
Subtitels after using VOB2Mpg
By demuwe in forum ffmpegX general discussionReplies: 2Last Post: 25th Jul 2009, 01:31 -
Subtitels off
By Russo in forum SubtitleReplies: 2Last Post: 18th May 2007, 11:05
Statistics
Newest guides
Latest tool updates
New media comments
