Hello all,
I have an nvidia geforce 8800 gt card with 2 DVI outputs (latest drivers)
I connected one of them to a 32" LCD with a DVI to HDMI cable, but i wasn't able to find a proper resolution that will display my desktop properly.
I tried many different options and combinations but nothing is proper.
Can someone try and help me with the problem?
thanks,
Eithan.
Results 1 to 11 of 11
Thread: DVI to HDMI resolution
What LCD TV ?
Usually the resolutions will be 1366 x 768 or 1920 x 1080, however you will have to consult the manual to confirm what you need.
What is the LCD resolution? is it a LCD TV or monitor?
And try google for nvidia pixel mapping and you will probably get some hints.
It's an LG 32" LCD TV.
Just to get some knowledge, even if i find out the native res of the TV, how will I set it?
is nvidia control panel the way to do it?
or there are other tools?
excuse me for my newbeness, trying to learn the subject.
thanks
Eithan
also,Originally Posted by eithan
i used to connect to the tv with a VGA cable and used 800X600. which worked fine.
and now i switched to DVI to HDMI cable that from what i understand from reading here, should be better. after i switched, this res still fits well, but from some reason, when i switch to that spesific res, the colors on the TV become almost grey and white. its strange, it happens only on 800X600 and only with DVI2HDMI.
any clue?
thanks
A 32 inch LCD most likely has a native resolution of 1366x768. Check the manual or some online resources. Most HDTVs support only a limited number of resolutions via DVI/HDMI -- usually the standard video resolutions of 1280x720 and 1920x1080.
What do you mean by not getting a "proper" display? Was small text fuzzy? Were the edges of the desktop cut off? You may have to revert to VGA to correct these problems. You will likely get a better picture from VGA at the TV's native resolution than via DVI/HDMI. The biggest exception would be a 1080p HDTV with a pixel-for-pixel mode.
jagabo,
the edges of the screen are cut off on any resolution, except
as i stated before, 800x600 which fits perfectly. but only in this case the colors change on the TV, not on the monitor. its strange. any idea why?
thanks again
Overscan. The VGA port is intended for computer/game connection and usually does not overscan. All other inputs have default overscan. Some models allow overscan to be turned off.Originally Posted by eithan
http://en.wikipedia.org/wiki/Overscan
Please tell us the exact model number of your LG TV.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
thanks for the quick answers,
my model is LG 32LC43.
is there any software way to deal with overscan, the colors look terrible.
Eithan.
I'm having difficulty finding any specs for this TV other than is has a 1366x768 native display resolution.
You should have a manual with it and it should have a section on PC connection (if supported) and resolutions accepted.
If it has a PC (VGA port) then you will find better luck interfacing at 1280x768 or 1366x768 from a computer.
Overscan addresses your issues with the edges being cropped but has nothing to do with "colors".
I suggest you use the VGA port if the TV has one.
Overscan is dealt with using desktop zoom modes in your display card software. These modes will lower image detail but will make the picture edges visible.Recommends: Kiva.org - Loans that change lives.
And note that the fact that the TV supports 800x600 via VGA doesn't mean it supports that resolution via DVI/HDMI.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / HDTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14 -
Resolution mismatch connecting PC (DVI-I) to LCD TV (HDMI)
By anoopaythala in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Feb 2009, 10:48
