VideoHelp.com Forum
    After clicking encode (trp to dvi) I hear the DING! and get a finished text in the progress window but there is no file to be found. What point am I missing here?
    Here is the Process Information:
    Encoding started on Sat Apr 11 10:33:42 HKT 2009
    FIXME:Hardenabling SSE and SSE2 without detection
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    CPU: Intel (Family: 6, Stepping: 11)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    success: format: 0 data: 0x0 - 0x356d000
    TS file format detected.
    DEMUX OPEN, AUDIO_ID: 0, VIDEO_ID: -1, SUBTITLE_ID: -2,
    PROBING UP TO 2000000, PROG: 0
    VIDEO MPEG2(pid=851)NO AUDIO! NO SUBS (yet)! PROGRAM N. 0
    Opened TS demuxer, audio: ffffffff(pid 0), video: 10000002(pid 851)...POS=0, PROBE=2000000
    MPEG: FATAL: EOF while searching for sequence header.
    TS_PARSE: COULDN'T SYNC
    Video: Cannot read properties.
    Exiting...
    The logfile indicates that it encountered an unexpected EOF marker. That caused the program to terminate before it really got going.
    You might have some luck using MPEG Streamclip to convert the TS into a "regular" MPEG file. Since this is just a file format change, not a re-encoding operation, you don't need the MPEG2 component (so ignore any error messages you get). Then take that MPEG and try again.
    Or, if you do have the MPEG2 component, you can use Streamclip to convert into DV directly. Your choice.
    Hope that helps. Post back if it doesn't.
  1. Imgburn auto correct file system doesnt ever complete..
    By Highroller in forum Authoring (Blu-ray)
    Last Post: 12th Oct 2011, 15:46
  2. mencoder wont convert the complete file, mov to avi|mov
    By bjornieB in forum Video Conversion
    Last Post: 19th Nov 2009, 07:42
  3. won't encode full file, and will only do certain file formats
    By GregDz in forum ffmpegX general discussion
    Last Post: 21st Jun 2008, 21:27
  4. Movie in a .rar file 99.9% complete, is there a way to extract it?
    By dexter30 in forum Newbie / General discussions
    Last Post: 10th Feb 2008, 07:55
  5. Replies: 3
    Last Post: 28th Aug 2007, 18:19
